Question about Motorola Mobility DROID RAZR MAXX HD
I have no APN settings listed on my phone. When I press the menu button, all I get is reset to defaut. how do I add an APN?
  • Official Brand Answer
  • 1,623 Answers
When your SIM is in your phone and you click reset to defaults it should query the network and set it up as default.
Motorola Support
Posted on May 03, 2015
Please my LG G4 dont have APN settings. How can I download it
Hi Yewande, Without knowing your internet provider I can't help you but you can find it by googling (APN settings for) + YOUR INTERNET PROVIDER.....CHEERS..
Apr 25, 2016 | LG G4
Change apn settings on alcatel one touch model A995L
The first thing you'll need to do is find the right APN settings for the network you want to use. You'll be able to find these at the support pages at the carrier website. The settings will look like this example for Straight Talk:
  • NAME: straight talk
  • APN: tfdata
  • PORT: 80
  • MMSC: http://mms-tf.net
  • MMS PROXY: mms3.tracfone.com
  • MMS PORT: 80
Once you have this information at hand, grab your phone.
Open the settings, and look for Wireless and Network settings. Once there, look for an option to see "more". You'll be presented with a list of options to select, and we're looking for something labeled "mobile networks".
Once you've found your mobile network settings, the rest will be the same on all devices. You're looking for the "Access Point Names" section. Tap to open it.
You should see a list with at least one APN on it. If things aren't working with the current APN, you need to add another. Don't modify or delete the one you see, instead make a new one and we can choose it when we're done. At the top of the page, or possible in a menu if your phone has a menu button, press the plus sign to bring up the "Edit access point" screen.
This is where you will enter the settings you got from your carrier's website. Two very important things here:
  1. Not every setting in the "Edit access point" screen will need filled in. Only fill in the items your carrier provides, and leave the rest as-is.
  2. Be sure to type in everything exactly as provided by your carrier. For example, default,supl,hipri is different than default, supl, hipri because of the spaces between items. Your carrier's system is set up to read an expected set of values, and any changes - no matter how minor - can and will break things.
Once you have the settings provided by your carrier entered, you need to save the APN. You do that by pressing the three dots in the upper right (or the menu key if your phone has one) and selecting the "Save" option.
Once your APN information is saved, go back one screen to the list we saw earlier. On this screen, tap the new APN settings you just entered to make them active.
Most times, you'll need to physically reboot your phone to use a new APN setting, but once properly entered, chosen and working, your phone will choose the correct one automatically whenever it's rebooted or Airplane mode is toggled.
Jan 23, 2015 | Alcatel Cell Phones
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 | Cell Phones
Cant recieve or send out mms
Here are the APN settings for your phone and T-Mobile.
These need to be correct for mms to work.
APN & data settings
To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Wireless & networks.
  4. Open the Access Point Names or APNs. menu (in steps above)
  5. If there is a T-Mobile APN, touch it. If not, press the Menu key, and touch New APN.
  6. Verify and update the following settings for the Data APN:
    • Name: T-Mobile
    • APN: epc.tmobile.com or fast.t-mobile.com (for LTE devices)
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not Set> OR Internet+MMS (depending on software version)
  7. Press the Menu key.
  8. Touch Save.
  9. In the list of APNs, delete all others that may appear. If there is a FOTA APN, you may leave that one. To do this:
    1. Touch the APN you want to delete.
    2. Press the Menu key.
    3. Touch Delete APN.
  10. Verify that there is a circle next to the one remaining APN to show it is activated.
  11. Perform a soft reset.
  12. Test your data connection, by accessing a web page or sending a picture message (MMS) to yourself.
Sep 15, 2014 | ZTE Concord Blue Smartphone - T-Mobile 832...
How do I delete the current APN and add the correct one for straight talk?
OK first of all go to settings, more, mobile networks, access point names, then press menu, select new APN, type the name of your service provider followed internet e.g MTN INTERNET, type Internet at where the APN is and then press menu again and select save. you are done
Jul 18, 2014 | HTC Inspire 4G Smartphone
Why droid razor can't receive picture messages
The simple answer is your settings are wrong, you can go to your carrier to fix it or a local repair shop.
The setting that is likely needed to be added or changed is called "apn" which is access point network.
If you feel comfortable with changing things in your phone; Go to settings > more.. > apn (if on screen) or mobile network > apn > menu button > Add or New > The next part will depend on the carrier you are on. The link is an example of Canadian carriers apn settings. Android Coliseum Rogers Telus Bell Fido Virgin Koodo APN List
Jun 04, 2014 | Samsung SGH-G600 Cellular Phone
Unlocked htc inspire need apn and mms
For the HTC Inspire on Family Mobile, you'll need to create two APNs.
1. hit menu -> settings
2. hit "Wireless and Networks"
3. hit Access Point Names.
4. hit menu -> Reset to Default
5. hit menu -> New APN
Enter the following settings exactly. They are case sensitive. Any setting I do not list here should be left alone. Please note that in the "APN Type" setting, there are no spaces after the commas.
APN: Phone
APN Type: default,admin,hipri
6. Hit menu -> Save
7. Hit menu -> New APN
APN: web.omwtoday.com
Proxy: 216.155.175.188
Port: 8080
MMSC: http://wirelessfour.mmsmvno.com/mms/wapenc
MMS Proxy: 216.155.175.188
MMS Port: 8080
APN Type: mms,supl
8. Hit menu -> Save
9. Make sure the first APN - "MEdia Net" - is selected by the radio button on the right side.
When you complete step 9, your data connection should drop and then come back after a few seconds.
10. Reboot your phone by holding the power button for 3 seconds and choosing "Restart Phone."
Done!
Mar 16, 2012 | HTC Inspire 4G Smartphone
Mobile network settings
Hi
To input settings/choose from presets...
Press Menu Button (The one with four small squares on it)Go through menu and tap "Settings"
Tap "Wireless and Networks"
Scroll to and tap "Mobile Networks"
Tap on "Access Point Names/APN's"
If your Network is not listed press
The Menu Button again (Four Small Squares)
and tap "New Apn"
You will obviously need the settings.
You can probably find these on your network providers website.
Most Service Providers offer a text setup service.
This will send a text message to your phone which you read and delete, then restart your phone and settings should be set up automatically.
Check your Networks website to see if this service is available.
I hope this helps!?!
Mar 10, 2012 | Sony Ericsson XPERIA X10 Cell Phone
How two use g p r s
If you need to add a GPRS connection to your phone, obtain the access point name and settings (including username and password if required) from your wireless service provider and add these settings to your phone by following next steps: Press HOME > MENU, and tap on Settings. Tap Wireless controls > Mobile network settings > Access Point Names. On the APNs screen, press MENU and then tap New APN. In the Edit access point screen, enter the APN settings. Tap the APN setting item to edit it. Press MENU and then tap Save to save the settings to your phone. This way you will connect using a GPRS connection.
Feb 14, 2011 | HTC Hero Smartphone
Network Connection error
This is a tutorial on how to add APN settings to HTC phones for your network providers. Example phone used is a HTC Hero but process is same for all HTC models.
Android APN and Data Settings Change for HTC Phones
  1. Go to settings -> wireless controls
  2. Go to Mobile Networks -> Access Point Names
  3. Click Menu and select New APN
  4. All you need to add for most networks is just the APN setting which can be obtained from your simcards network provider
  5. Press Menu and Save
  6. You are ready and have configured data connection settings.
Enjoy your HTC phones unlocked for Voice and Data for any network. see video below
May 14, 2010 | HTC Reusable Screen Protector Hero /...
Motorola Mobility DROID RAZR MAXX HD Logo
73 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
