Question about Epson Stylus Nx130 Mfc Inkjet
Epsom NX130 wont print after replacing new ink cartridge. Have taken all out turned off power. Not working
Tried cleaning head, and youtube suggests like turn all off for 5 mins take all cartridges out and leave for 5 min
  • Epson Master
  • 2,835 Answers
Does it try to print, but the page is blank, or does it simply sit there?
If it tries to print, but nothing comes out, you may have a clogged print head.
If it doesn't even try, did you use a genuine Epson cart, or an after market? Epson printers won't print if even one cart is empty.
Posted on May 02, 2015
Have just installed new ink to my Epsom Stylus sx215 but wont print, just blank pages
Ensure cartridge fitted 100%, and you have taken off cartridge protectors, but the Printer should tell you why it's not printing !
sound simple to replace ink cartridge, but it can be tricky.
s
Feb 14, 2015 | Epson Stylus Office Equipment & Supplies
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
Hi I brought some Wilkinson ink cartridges that are compatible with epsom T0715 for my Epsom sx210 printer. Everything worked fine, now after approx 2 weeks I'm unable to print as it keeps saying...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
May 10, 2011 | Office Equipment & Supplies
Our daughter has an Epsom PaperMate 240 printer. Until now we have used only Epson cartridges but last time we bought a compatible cartridge. It ran 4 prints then the "out of ink" message was...
Hi
First it is not advisable to use other catridge other than epson because it will damage your printer. Because the printer have specialized chip that detect epson cartridge only. It will be okay for 2-3 times but later on it will say out of ink even you put new cartridge. I suggest if your printer had reset ink cartridge, just reset it and turn off your printer and computer for 5 mins. Then to restart on fresh mode and then try to print again. Next time use epson only because later it will not detect ink cartridge any more.
I hope it helps you.
Jan 11, 2011 | Office Equipment & Supplies
HORIZONTAL PINK LINES
The nozzle check pattern should be complete, no gaps and breaks on the lines. Try to turn of highspeed printing, It is on the advanced tab of the printer properties window.
Apr 23, 2010 | Epson CX8400 All-In-One InkJet Printer
I have replaced my ink cartridge on my Epsom TX110 and it wont recognize the new cartridge it thinks its none genuine but its genuine its the Epsom 91N cartridge. i have tried cleaning chip that doesn't...
try this one link below, or else you need to replace printer head assembly.
http://downloadaccess.net/search.php?PID=851f9112-c11b-4e76-ba40-c351bd1419f5&q=free%20download%20epson%20tx110%20resetter%20software
Mar 25, 2010 | Epson Stylus NX400 InkJet Printer
One colour cartridge on epsom sx200 is empty yet it wont allow me to print in black only
umm... this is not a solution because I don't think there is one apart frombuying new inks. Epson and all other inkjet printers do this to preventthe coloured print head nozzles from getting blocked. If they are notused for a long time the ink dries up and blocks the nozzles. Epsonrecommends printingat least once a month with all colours to prevent this. Printing inblack only option will only work if the colored inks are OK. Wheneverthe printeris turned on it performs a head clean, this is why the coloured inksget used over time even though they are not used for printing.
www.Quikshiptoner.com
Nov 25, 2009 | HP LaserJet 2840 All-In-One Printer
Epsom dx4450 how to change ink cartridge
Replacing the cartridge:
1. Make sure the printer is on and open the printer cover
2. Make sure the printer is paused and the output tray at the front of the printer is lowered
3. Hold down the cleaning button for three seconds until the print head moves slightly to the cartridge replacement position, and the power light flashes when the print head is in position. Do not move the print head by hand, it will be damaged
4. Lift up the clamp that holds the cartridge you want to replace as far as it will go.
5. The cartridge will rise partly out of the cartridge holder. For black ink replacement, lift up only the smaller clamp on the left.
6. Lift the cartridge out of the printer and dispose of it properly.
7. Remove the cartridge from its protecting bag. Remove only the yellow tape seal from the cartridge. The yellow tape seal must be removed. Leaving the tape on when you install the cartridge will permanently damage it. Do not remove the tape seal from the bottom of the cartridge.Otherwise ink will leak.
8. Lower the ink cartridge into the cartridge holder with the label on the cartridge face up and the arrow on the cartridge pointing to the rear of the printer.
9. Press the ink cartridge clamp down until it locks in place. Do not press the cartridge itself.
10. Press the cleaning button. The printer moves the print head and begins charging the ink delivery system. This process may take a few minutes to complete. The power light continues to flash while the printer performs the ink charging operation.
11. Never turn off the printer while this light is flashing. Doing so can result in incomplete charging of ink. Even if you do not press the cleaning button, the printer moves the print head and begins the ink charging process about 60 seconds after you replace the ink cartridge.
12. When the ink charging procedure is finished, close the printer cover.
Sep 16, 2008 | Epson Aculaser C1100 Printer
Epsom printer dx7450
you could have one of several problems here.
i,d suggest printing several test pages, and observe whether the red comes through after this.
if this does,nt work remove the cartridge, and replace ensuring the cartridge goes in with a firm click.
finally if you have the original software installed for the printer, try a head cleaning operation.
Mike @ Compurepair.
Jun 22, 2008 | Epson Stylus C60 InkJet Printer
Red ink not printing
i think your head is bad..
change the head itself..
it will fix you..
thank you.
Feb 15, 2008 | Office Equipment & Supplies
Epson Stylus Nx130 Mfc Inkjet Logo
96 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
