Question about Welding Tools
Miller spoolmatic pro 30A, It still feeds, but won't arc. Less than a year old, what can I try?
  • 52 Answers
Less than a year, warranty. Otherwise, of the machine welds with the other gun, then the spoolgun most likely has a bad weld cable.
Posted on May 07, 2015
    Top Expert:
  • 10,875 Answers
Under warranty get it serviced before bigger problems later
Posted on May 02, 2015
    Top Expert:
  • Welding Tools Master
  • 50,098 Answers
Check that the earth lead is correctly fitted to the machine and the work
as it should have a warranty, if that doesn't fix then back to the shop for a repair.
  • 991 Answers
Run the first layer of wire of the spool you will see a color change. The wire gets a fine layer of oxidation and this causes a bad contact.
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    When I push the trigger I lose my voltage to run the feed motor, the motor works with other power source
    Had the same problem with mine but mine isn't miller and don't know if your's is built the same but if you access the inside of the machine there's there's a large copper spool inside and that wire feed handle is powered through it. The connection heats up over time and becomes a short. I re spliced mine then soldered it and then cut piece of copper tubing and crimped it around the connection and soldered that as well.
    Corrected the problem and I tried pretty much all listed solutions other then this first. Tried the new liner in the torch, the new tip and clamping the wire feed assembly with a clamp instead of the tensioner. All failed. I stumbled on to the fix accidentally when I was trying to install a more heavy duty fan. Hope this helps. Good luck.
    Apr 21, 2016 | Miller Spoolmatic 30a Mig Spool Gun 130831
    My wir burns up at the feed wheel before it goes to the sleve
    did you forget to reverse the wire .seems like I read that someplace . many newer ones thay added a switch for that purpose .
    May 07, 2015 | Miller Spoolmatic 30a Mig Spool Gun 130831
    I have a miller 211 and the fan cuts on but nothing lights up and no wire feed
    If this is the auto set version, is it under warranty? Less than 3 years old? If so take it to a shop and fix should be free. Otherwise, the fan motor is also a transformer, which puts out 24 vac to run the board. So could be fan motor or the board itself.
    Feb 21, 2015 | Miller Welding Tools
    Spoolmate 100 wont feed
    Check for binding int he inner sleeve first, then increase tension as long as feed motor spins. If feed motor does not spin check wiring to make sure it is connected correctly.
    Sep 18, 2012 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
    Our MillerMatic 175 wire feed cannot be adjusted down enough. The rheostat seems to function, but even the lowest setting is now way too fast.
    Your Millermatic 175 has syncronize wire speed-voltage feature in order to reduce the wire speed first reduce your heat (voltage). Try again.
    If this was useful to you please vote. thanks.
    Feb 10, 2011 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
    Millermatic 180 wire don't feed lights won't come on fan keeps running
    Machine will run only on 220V, check your braker nust be at lest 20Amp.
    Dec 18, 2010 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
    Wire won't feed or arc fan runns
    Look for a reset button on the case. Make sure that you have power to the machine and at the power socket. If everything looks ok outside, you may have to investigate your warranty. Good luck!
    Jan 04, 2010 | Miller matic 140 Mig Welding Package W/As...
    I have a miller 180 autoset that does not feed the wire
    If your welder is less than 3 years old your local Miller authorized service center will repair it for FREE. They can also check the serial number of your welder over the phone to see if it is still in warranty. For goodness sake DON'T tell them you've been mucking around inside the welder or they won't be able to help you.
    That said, if the welder spins the feed wheels without any wire between them it probably isn't the board. There is the switch in the gun, the board, and the motor and brake assembly all needed to feed the wire.
    Oct 18, 2008 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
    Welding Tools Logo
    288 people viewed this question
    Top Welding Tools Experts
    Bill Boyd
    Are you a Welding Tool Expert? Answer questions, earn points and help others
