Question about Garden
Why won't it start?
Changed gas, new plug, checked coil, good bright spark. Put on full choke, removed plug - loaded with fuel
    New Friend:
  • 36 Answers
1/. Common problem with two stroke engines is the spark plugs, quickest way to solve is take the spark plug out pull the engine over 2 to 3 times.
2/.This ensures cleaning any surplus two stroke oil is getting through & is removes surplus of fuel.
3/. Check plug is cleaned & warm spark end of plug up (over a lighter few seconds ensure it's warm replace & then try without giving to much choke this should help fire the engine. Best Wishes, Crossf.
Posted on May 03, 2015
  • 1,169 Answers
Although two cycle are simple engines the various problems can appear to have the same symptoms. It can take someone experienced in their repair to diagnose and repair them.
On two cycles there can several reasons why you would have a wet plug.
  • Flooding carburetor (multiple reasons why the carburetor may flood)
  • Plugged spark arrestor on the muffler.
  • Struck Piston (lack of compression)
  • Heavily scored piston/cylinder (lack of compression)
  • Flywheel key sheared (engine ignition out of time)
PS: The finger over the spark hole is not an valid check to see if the engine has enough compression to start. Two cycles require at least 100 psi to start and 4 cycles it is a bare minimum of 60-70 psi.
Posted on May 02, 2015
  • Henry Faiola
    Henry Faiola May 03, 2015
    Eugene,thanks for your imput.but my problem was my fault.I had sold my pontoon and had a
    gallon of out board motor oil I kept.Took my
    trimmer to authorized dealer.They inspected the cylinder wall,badly scored.Informed me
    engines will not start when this happens.The
    out board motor oil is a no-no for air cooled engines,only to be used in water cooled engines. Cost to repair exceeds value.
  • Eugene Rounds May 03, 2015
    Usually does when it comes to cylinder and piston replacement.
    When comes to Outboard motor oil it is different the outboard fuel oil that is design mixing with fuel I have used it for years without problems. I have since over to a multi-mix oil as I got tired so different cans of mixed fuel of sitting around.
    Top Expert:
  • Garden Master
  • 51,348 Answers
It is flooding . turn off the choke and remove the plug
dry the plug and pull the rope about 10 times to blow all excess fuel ot of the system
refit plug and try it again
Seems my Poulan Chainsaw P3314 is flooding.
Ron, the excessive gas could be the result of continued start attempts with a weak spark or a bad plug or a carboned plug. If none of the carb adjustments have not been turned or twisted prior, I'd suggest obtaining a fresh spark plug. Make sure the gap is correct. Blow out the cylinder with compressed air to vent all the residual gas/oil within. Ground the new plug against the engine and pull the cord. You should observe a fairly bright spark at the plug. If no spark you could have a faulty coil/ignition module. If a bright spark is present, install the plug and give it full choke and attempt to start. It should attempt to start within a few pulls....when it does, go immediately to HALF-choke and pull again and it should start.
Nov 11, 2015 | Poulan Pro 14" Gas Chainsaw 33CC P3314
I have an 84 firo changed plug still have orange spark
is it getting fuel? (gas) is choke working..84 should have a mechanical choke..did you maybe get the wieres crossed.. check timing..
Dec 15, 2013 | 1984 Pontiac Fiero
Craftsman push mower will shut off after using it for over a half an hour like it overheated and it won't start again until it cools down, any suggestions?
If it dies try removing the gas cap. If the gas cap vent is plugged it will do what you described. The other area to check is the coil or what Briggs sometimes calls an armature. You can buy a cheap spark tester at an auto parts store. When it dies put the spark tester on and if there is no spark then that is probably from the coil failing when it gets hot.
May 18, 2012 | Garden
What should I do with my husqvarna 130BT because I put in too much oil with the gas and it won't start?
First, you need to dump all of the fuel out of the gas tank, Preferrably into a gas container. If you know how much oil you dumped in, you can calculate how much more gas to add. You could also just dump the gas, re-mix some new gas and oil, whichever you prefer.
If you are comfortable doing this, remove the fuel lines going to the carberator and let them drain into a pan. Pump the fuel primer to purge the gas out of the carburator, and then re-install the fuel lines. This might help you get it started a little faster, but its not necessary. You can burn the old gas in the engine at it will be fine.
Next, remove and replace the spark plug. Its probably fowled out with too much oil. Keep a can of carb cleaner and a small wire brush handy, you may need to clean the spark plug a couple times. If it gets too dirty, you can replace the spark plug with a new one. Do not burn Carb Cleaner in your engine for long periods of time, it will damage the engine.
After you have installed the spark plug and put some correctly mixed gas in the tank, Try to start the engine again. There will be some residual fuel in the fuel lines going to the carberator, so you will need to burn off that gas.
If you can't get it to start, try these steps:
Choke off, throttle wide open, crank several times. (or let it sit in the sun for a couple hours) (this corrects flooding)
Prime carberatur, Choke full on, throddle idle position, crank until it fires once but does not start.
Choke half, crank until it fires again or starts.
If it starts skip this step: (Choke off, crank until it starts).
Keep the choke on half for about 10 seconds and let it idle.
Put the choke off and let the engine warm up for a couple minutes.
After warmup, test the throttle to see if it will run at full throttle (it may take some fluttering until the engine is fully warmed up)
Let the engine run at full throttle for a few minutes. The exhaust may be a little more blue-smokey than normal...this is the excess oil burning...totally normal and harmless.
Mar 25, 2012 | Husqvarna Garden
I have two craftsman leaf blowers that will not start, have changed the plug, is there a coil I need to check?
With the plug removed but connected to the spark plug wire if you pull the cord do you get spark? If so try pouring a cap full of gas in the spark plug hole and reinstall the plug and wire and try to start it. If it starts and stalls then you are not getting gas thru the carburetor. Check the fuel filter in the tank. Also check all the fuel lines and the primer ball and see if they are cracked. Also check the carburetor to see if the choke is opening and closing.
Thanks for using FixYa
Aug 19, 2011 | Craftsman Garden
I have a 2003 crf 230f the battery has juice I put in a brand new sparkplug its getting fuel full tank of gas w gas on messed with choke but wont start Help please
remove fuel line from carbi and turn the fuel **** on to see if fuel is getting through. if you have fuel at that point check to see if you have spark at the plug, if there is no spark you may have a coil problem
Jun 12, 2010 | Motorcycles
I can't get my Poulon leaf blower to start
So far everything looks good. You're getting fuel, and you're getting spark. Only problem, is you've gotten too much fuel in it, and need to get rid of some before you can proceed. Take that spark plug out, and pull the starting rope hard several times. This will force the largest amounts of fuel out. Now's the part where you'll have to trust me. Use a match or a lighter to "flash" the cylinder. Make sure you don't have excess fuel spilled over the blower, but hold that match or lighter right up to the spark plug hole, and it'll "puff" at you. Please don't look into the hole while you're doing this. Flash the cylinder, and then pull the rope again, and flash it again. Next, make sure the spark plug is dry then put it back in. Set your choke to full choke, and pull until it hits once. Then put the choke on half, and it should start within 3 pulls.
Mar 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have poulan 2150. it will not start.get gas and spark.
Has it been sitting around for a while not being used ?
If so I would dump the fuel out into an appropriate container and fill saw up with a fresh mix of fuel. I also ALWAYS put in about a cap full of SEA FOAM.
Make sure spark is nice bright blue, if not install a new plug.
Now pull on the choke, pull it once or twice, and shut off the choke.
Now does it start ?
If that does not start, I would pull the spark plug, drip a little fuel mix in, put plug back in torqued to mfg. specs. and see if it fires now ?
Please let me know what happens.
Feb 06, 2010 | Garden
Got given a old yz 80 changed piston and rings its fireing but wont start?
I'll start with the obvious.... have you tried removing the plug, putting a little gas in the cylinder, putting the plug in and wire back on and then kicking it over? If it starts, runs for a couple seconds and dies (burns off the gas you just put in there), it's a fuel or fuel delivery problem. Has the carb been cleaned, the needle and seat checked, the float height checked, air passages cleaned out, etc.? These carbs are famous for getting gummed up after sitting a while. (I have 4 dirtbikes and clean the carbs every spring before firing them up for the first time). Is the oil to fuel mix ratio correct? Too much oil will cause this as well. If it doesn't start with gas poured in the cylinder as mentioned above, check to see how strong of a spark you have and if the plug is gapped correctly. The spark should be bright blue. Hopefully you know how to check this, but if not, take the plug out, put the plug wire back on the plug and lay the electrode end of the plug (spark end) up against the cylinder head with the end of the plug touching metal and kick the kick starter over. You should see a bright blue spark. If it's a weak spark (not bright blue) it's an electrical problem such as a faulty coil. (WARNING: DO NOT HOLD THE PLUG IN PLACE WITH YOUR BARE HAND when kicking it over. You will get zapped good if the coil/spark are ok.) Try these troubleshooting tips and then let us know the result. We'll go from there.
Oct 29, 2009 | 2003 Yamaha YZ 125
Garden Logo
164 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
