Question about Garden
How do I replace the gun and hose on my Husky 1800 powerwasher?
I'm having trouble taking the old one off. Is there a easy way to replace this item?
    Top Expert:
  • Garden Master
  • 42,122 Answers
The hoses are normally a push in with an "o" ring seal
they are held in by a collar that you unscrew to release and then pull the hose out
Posted on May 02, 2015
Husky 1800 Pressure Washer motor will not turn off when wand trigger is released
I think you have one of two things going on hear, an overpressure problem or a carburetor issue with the engine.
Jul 25, 2017 | Husky Garden
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    Husky powerwasher 1800 parts schematic
    http://huskypowerwasher.com/manuals.html
    Nov 21, 2013 | Garden
    We are having trouble getting the spray gun to pull the paint through. It will spray air but does not spray paint.
    when you pull the trigger can u see the needle moving backward? if so, then it's either the paint is too thick compare to the nozzle size or the passage for paint is blocked. try to take the nozzle, needle and the cup off and give it a good clean!
    Sep 05, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
    Was using our powerwasher,,it;s 3 yrs old..have only used it 4 times...and the water just stopped coming outta the gun...my husband thnks the pump went on it...we have only used it 4 times..
    On the round piece that the garden hose screws too there is a filter screen in there. Remove it gently with a screwdriver around the edges and clean the screen then put it back in.
    Mar 16, 2011 | Honda Garden
    I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
    the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
    Nov 13, 2009 | Porter Cable Air Tools & Compressors
    Need parts diagram for Husky Pro Multi-purpose spray gun
    Call tech support, theyll fax or email you one...
    Apr 20, 2009 | Air Tools & Compressors
    Husky powerwasher replacement part
    Hard to find hose repairman,maybe radiator shop,but you will find you will probably have to by new,you would need special high pressure hose crimpers,someone like hydrolic line repair.
    I know.... Please rate a fix ya Thanks jj505
    Apr 11, 2009 | Garden
    Need new gun and connection to gun
    The DuraBuilt and Coleman pressure washers have a gun that tends to leak through the plastic clyinder wall that holds the plunger that moves with the trigger. You won't see the holes, but if you remove the upper half of the housing, hold the plastic tubes in place with one hand and turn on the water, not the motor, you will see water shooting through the wall.
    Amazon sells an exact replacement gun and hose. FAIP PowerWasher Replacement Gun and Hose #80012. Mine does not leak at all and was $29 shipped.
    Dec 14, 2008 | Coleman Powermate DuraBuilt 1400 PSI...
    Garden Logo
    89 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
