Question about Summer Infant Nature Purest Soothing Comfort Bassinet Hug Me
I need instructions to snap it together - Summer Infant Nature Purest Soothing Comfort Bassinet Hug Me
How do I PUT together the presser foot. the part that snaps into foot
Here's a manual you can download. It should have instructions for attaching your presser foot:
Instruction Manual White 955
If you are using snap-on feet, be sure that you have the low-shank snap-on adapter for your machine (looks something like these) that actually clamps onto the presser foot:
Snap on Shank Low Shank
Aug 09, 2015 | White Sewing 955 Mechanical Sewing Machine
Instruction how to put nania beway 123 car seat together
The two parts hanging down on the middle bottom of the back piece should snap into the slots on the base. Push down until you hear it click.
Jan 02, 2015 | Nania Baby Gear
Need instructions on how to change my clutch on my 97 roadking
All you have to do is drain and pull the primary cover. Now, I can't remember whether the '97 clutch had the bolts that hold it together or the snap ring. If it has the six bolts holding the clutch spring in, simply take the bolts out and your clutch assembly comes apart. You can change the fiber plates and the spring plate in the middle. If your clutch is held together with a snap ring, you'll need a special tool to disassemble the clutch. You can replace the friction plates, steel plates and the spring plate without taking the entire clutch off the mainshaft with either clutch.
Good Luck
Steve
Jun 04, 2011 | Harley Davidson FLHR-FLHRI Road king...
GaSeveral years ago, we bought our granddaughter the zoo set and put it together for her. Then they moved and had to take it apart. Unfortunately they lost the directions. We are going out to visit them,...
The Playmobil company doesn't actually provide assembly instructions just a paper which includes all the pieces in the zoo.
Not sure which Zoo you have but here are two links to each one they sell. Hopefully the pictures will help a little bit.
Large Zoo
Children's Zoo
It's probably best to start by building your animal pens and the main zoo structure by snapping the pieces together. The pens and structure are built of the white brick pieces, the yellow railings and the green roof pieces. Assemble any animals that require assembly, such as the peacock. Simply match up the two pieces and snap them together. Decorate each exhibit with plants by snapping them into the plant holders.
Hope this helps!
Mar 05, 2011 | Playmobil Toys
Need instructions on replaceing a dimmer switch on a 2004 impala with criuse control
behind sterring wheel is a 2 piece cover, remove screws from cover remove cover [it also snaps together] after removing the cover the switch iseasily replaced
Feb 08, 2011 | 2004 Chevrolet Impala
How do I put together the Disney Magic Rise Oven? Does it snap together or do I need to undo the screws?
I had the same problem. It does in fact 'snap' together, but you will have to put a little umph into to it. Good luck and Merry Christmas!
Dec 25, 2010 | Disney Princess Magic Rise Oven
How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Mar 15, 2010 | Wahl 8550
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Summer Infant Nature Purest Soothing Comfort Bassinet Hug Me Logo
132 people viewed this question
Top Summer Infant Baby Care Experts
masud
masud
Tom Chichester
Are you a Summer Infant Baby Care Expert? Answer questions, earn points and help others
