Question about Thule 2003 Chevy Tracker - 4-door, with factory roof rails - Base Rack System
REPLACE POWER PASSANGER SIDE MIRROR ON CHEVY TRACKER
POWER OUTSIDE MIRROR
Mirrors aren't working
Could be a bad connection or switch could need replaced or motor that moves mirror needs replaced...I would start by having power going into mirror checked that is not working to make sure it is getting power and if so this would indicate that it is in mirror motor....hope this helps and good luck and please rate my post if you find this info helps..
Aug 16, 2012 | 2001 Lexus LS 430
Have to replace the passanger side mirror on 2000 dodge stratus. how do i go about doing this
remove the triangle trim piece on the interior side of door (usually snap on a delicate pry with a flat head screw driver will do the trick)
next remove the (3) 10mm nuts securing the mirror to the door, next unplug the mirror by squeezing the plug connector, pull the mirror of the outside of vehicle. Reverse this order during installation and you should be fine.
Note the mirror may fall and scrath the paint while the nuts are off, keep a hand on the old mirror to prevent from falling during removal
Feb 19, 2011 | 2000 Dodge Stratus
How do I replace a side mirror chevy corsica?
Please don't forget to rate....thanks:
Removal & Installation The door outside mirrors are stud mounted to the door filler. The mirror glass face may be replaced by placing a piece of tape over the glass then breaking the mirror face. Adhesive back mirror faces are available. Left side flat and right side convex mirror faces must be replaced with the same type mirror face when surfaced.
  1. Remove the door trim panel.
  2. Remove the upper trim panel.
  3. Remove the sound absorber.
  4. Remove the (3) nuts.
  5. Remove the control cable from the upper trim panel.
  6. Remove the filler and mirror.
To install:
  1. Place the filler over the studs on the mirror.
  2. Install the control cable through the filler and connect to the upper trim panel.
  3. Install the (3) retaining nuts and tighten to 42-72 inch lbs. (4.7-8.1 Nm).
  4. Install the sound absorber, upper trim panel and trim panel.
Mar 06, 2010 | 1996 Chevrolet Corsica
Replace the passanger side mirror on a 2004 ford
It is held on by 2 phillips head screws that are accessed from the inside of the door (remove the panel, remove the screws and the mirror falls down. Remove the electrical connection to the mirror motor and you are done/
Oct 10, 2009 | 2004 Ford Explorer
Im trying to replace the passenger mirror, need to
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Once the panel is off, you will see two or three bolts securing the mirror assembly onto the door
Sep 21, 2009 | 2003 Chevrolet Venture Passanger
Passanger side mirror for a 2000 saturn sl
You can get one online at advanceauto.com. For a manual mirror it's $49.99, and for the power mirror it's $59.99
Jun 07, 2009 | 2000 Saturn SL
Need to replace passenger side power mirror on 2004 Chevy Tracker
jean you might try searching google for an answer on this one. good luck
Jun 28, 2017 | 2004 GMC Envoy
1999 Chevy Monte Carlo Passanger side mirror replacement
try "autozone.com" or your local library for diagram and step by step instructions
Mar 08, 2009 | 1999 Chevrolet Monte Carlo
Thule 2003 Chevy Tracker - 4-door, with factory roof rails - Base Rack System Logo
35 people viewed this question
Top Thule Luggage & Travel Experts
Daryl Gleaton
Paul Belkin
Paul Belkin
Rod Doney
Rod Doney
Are you a Thule Luggage and Travel Expert? Answer questions, earn points and help others
