Question about Hampton Bay 24002 Ceiling Fan
How to fix pull chain for lights on a ceiling fan?
Don't know the brand. Just clicked on first option for brand. Have had for years. Pull chain for the light portion seems to be all the way out or is just stuck. Will not pull down anymore to turn light on.
    Sergeant:
    Champion:
  • 294 Answers
You will probably have to replace the switch that is controlled by the chain. You will need one withe the same number of wires coming out of it. Find out the type of fan and google it. If it is a cheap fan I would replace the entire unit, it if is also old.
Posted on May 01, 2015
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
If you only pull once to turn on light, go to Home Depot, Lowes or local hardware store and buy a two wire light pull chain switch. Just wire it the same as the old one.
Posted on May 02, 2015
How to fix a ceiling fan light fixture?
If the pull chain doesn't make a clicking sound when you pull it, you need a new switch.
May 10, 2016 | Hunter Dryers
Pull chain hanup on glass light cover
Take the glass off and see if there is a hole in a small plate below the light sockets. The pull chain should go thru this hole first before the glass. I don't know if this has it or not being that it's a low-end store brand fan.
Jul 28, 2013 | Hampton Bay Ceiling Fan. Hawkins 44 in....
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
PULL CHAIN FOR LIGHT BROKE AND IS INSIDE THE UNIT. HOW DO I GET THE LIGHT UNIT OFF TO GET TO THE PULL CHAIN UNIT.
"PULL CHAIN FOR LIGHT BROKE AND IS INSIDE THE UNIT. HOW DO I GET THE LIGHT UNIT OFF TO GET TO THE PULL CHAIN UNIT."
My oh my!
I don't know of any shortcuts, and the working position does not make the operation a pleasurable one. Not in Summertime!
The time I had to repair that, I needed to pull the whole fan down. Once the whole fan was down, the rest was easy!
It's easier that it appears, but mark all the wires connected in the box.
There is USUALLY a steel cable attached to the fan assembly and the box, to prevent the thing accidentally falling on someone's head.
If you don't have a helper, taking the blades off may be a good idea, but don't take my word for that. Putting them back on was no picnic.
FYI. If you don't have any bead-chain handy, a suitable lenght of sash cord is probably the best replacement.
May 15, 2011 | Hunter (25417) Ceiling Fan
The ceiling fan do not occilate the light turn on but the other does not work propperly
mcdevito75 here, Both the fan and lights work off the wall switch, for the fan to work there is also a pull chain close to the ceiling on the fan shroud you have to pull that chain to get the fan going and 1--2 more times for various speeds. If by chance the fan is brand new, reove the blades and check for stops in the fan motor, right where the blades hook up, these are in place from the factory and have to be removed for the fan to work, they pull right out.
Jul 27, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Hunter 52, fan works but light no longer works with remote or chain pull
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Jul 19, 2010 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan pull chain connected but does not click on
There is a pull chain switch inside the fan termination housing. you will have to take the little cover off and remove the switch. it has 2 small screws with wire landed under them. Turn off the power at the breaker before working on the switch. take this little ****** out and put in a new one. you can get them at the Home Depot or equivelant. it don't matter if the new switch is a little bigger but it still has to fit. use some judgement here. wire it in the place of the old one, turn the power back on at the breaker and it should be ready to go. Presto.
Aug 16, 2009 | Hunter 20531 Vista Brushed Nickel Ceiling...
Light not working by pull chain or remote.
I would try removing the remote part. Connect the two main (light & fan) wires direct to your house main. Then if the pull chain works then you just need a new remote unit.
Feb 13, 2008 | Heritage (5BUW52NK2YQ) 52" Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
161 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
