Question about Drills
Where do you put batteries for coleman max lattern model 4365?
Where do you put the batteries? There is a housing on bottom of Lattern for electric charger however where do you put batteries Suppose to take 8 d batteries
    Master:
  • 335 Answers
The bottom comes off or opens up. If you don't see a battery door, try rotation the bottom (to the left) while holding the top. Google for a manual if that fails.
Posted on May 01, 2015
LOST BOTTOM OF MY COLEMAN MAX LED LANTERN 4345-701 WHERE CAN I BUY THAT REPLACEMENT PART. ALSO, SOME WEBSITES SAY IT TAKES ONE BIG BATTERY... OTHERS SAY IT TAKES 8 d BATTERIES. HELP !
As far as the missing part, you can probably go to the manufacturers site and find one. You may find it on E-Bay. The one large vs 8 D cells is an easy one. I have lights that use either. Some lights come with an extra part that looks like a large battery but is actually a holder for 8 d cells that will replace the large battery.
Dec 08, 2016 | Coleman Camping, Backpacking & Hiking
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
My Dremel max won't start
Check and replace brushes as necessary. Also, check that the actual electrical switch is functional. I had to add a drop of crazy glue on the tip of the interior plastic handle housing that supports/puts pressure on the electrical switch to keep it in position. The off/on thumb slider actually extends well into the housing and activates the electric switch by moving back and forth. Over time, the plastic wears and does not plunge the on off switch button. A drop of glue on the tip of the plastic post extends it & causes enough pressure to make the electric switch to function again. Brushes (filed to fit) and glue = good as new Dremel :o)
Dec 08, 2012 | Dremel Multi Max Kit
I would like to know how many square feet a Model # BRCQ0421BD Serial # 990905429 Coleman Central Air Conditioning Unit will cover. The unit supply is 208-230V 1 PH 60 Hz 10.8 RLA 97 LRA.
The Old Rule of Thumb is 400 square feet per ton, but you really need to do a heat load calculation to be safe. A lot of windows on the west or south side of the house will really increase your load and you may need a lot larger unit. Insulation also changes your load so you may be able to cool a larger area. You may be able to get the Heat Load Calculation Form either online or from Johnstone supply. They are on the internet.
Aug 07, 2012 | Coleman Heating & Cooling
I JUST bought the coleman mini led headlamp and i don't know how the batteries are supposed to go in. the back will not open and there were NO instructions.
TO INSTALL OR REPLACE BATTERIES
1. Rotate body of headlamp until lights are pointing down and battery cover tab is to the front.
2. Insert edge of buckle on headband or a coin under tab and twist to unlock and remove battery cover.
3. Install 3 "AAA" cell batteries in the correct orientation as shown on the battery housing. Make certain all 3 batteries are installed
correctly.
4. Replace battery cover by first inserting the tabs on the back of the battery cover under the back edge of the battery housing, and
then rotate down until battery cover snaps into locked position.
For the manual: http://www.coleman.com/coleman/images/pdf/4343-704.pdf
Feb 21, 2011 | Coleman 3AAA LED Headlamp
I just bought the coleman Max mult-colored headlamp and i cant figure out how to put the three AAA batteries in
In the headstrap is a plastic 'key' that you use to remove the battery cover (opposite side of the headlamp from the switch). Once you remove the cover, you can shake the headlamp to let the battery cartridge slide out of the headlamp.
Pay close attention to which way the batteries go in--if you put a battery in the wrong way you can easily bend the springs inside!
Oct 26, 2010 | Coleman 3AAA LED Headlamp
Coleman 6250 PoweLeaking gas at bottom of motor housing. Can not
The gas is leaking from carb but in the motor not out.
You should check and repair the carb flow valve. The floating unit may be full and bent down.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
What to do with exhaust pipe to close to house and freezing up door and house. exhaust pipe comes out of the wall from furnace in basement 12inches and on this pipe is a tee vented on the top and the...
Best solution is to put a reducer instead of the tee this is recomended by some companies to increase velocity of exiting gases. If you increase the length this will have a affect of icing in the pipe. Try the reducer if its 2" reduce to 1 1/2" or 3" reduce to 2"
Best regards,
Tinner
Dec 15, 2009 | Coleman Heating & Cooling
I have a GE Hurricane lantern model # 17000, how do I get it apart to put new batteries in it? There is an arrow on the bottom of it pointing to oppen one way and close the other, but nothing is budging.
I have the same latern. Apply a bit more force to rotate the bottom lid in a counter-clockwise direction. There are threads on the inside of the botton lid. To replace the battery or bulb you go through the botton of the lattern.
Jun 30, 2009 | Camping, Backpacking & Hiking
Powermate 6250 model pm0545007.01 engine runs no a.c. output
You will need to install new diodes,they are located in the plastic housing behind the receptacles...It looks like little spark plugs..They work to put dc voltage to the rotor,without the exciter voltage applied,you will not get ac power out..The part number is 3483.01....You can buy these online for about $6 each,they have 2 inside the generator,and you should change both.
Dec 17, 2008 | Coleman Powermate Premium Plus 6250W...
Drills Logo
122 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
