Question about Miscellaneous
We have a 02 Coleman caravan that the floor needs replacing trying to figure out how to take the side slideout off to be able to fix floor can u help
  • 1,889 Answers
Move your slideout in one foot into the RV then remove the "picture frame" edge of the slideout the; using a forklift to support the slideout release the slideout locks located under the slideout on the rails; extend the slide out as the forklift reverses untill the slideout is free re-installation is the reverse of these instructions
Posted on Jun 08, 2015
How to adjust slideout on Fleetwood 39s discovery motor home it is draging floor when retracting
I cant understand your writing or wording,get a Haynes repair manual
Nov 24, 2014 | Cars & Trucks
The slideout is not working. No noise everything else is working cannot locate fuse for slideout?
There will be an inline circuit breaker that controls the power for the slide. Some are automatic reset and others have a small black button on the side that will need to be pushed in to reset. These are usually located in an outside storage compartment.
Mar 23, 2014 | Keystone Bullet 260FB RVs
Trying to remove 1874 Microwave from 05 Dynasty. Mounted in slideout
Dynasty, There 2 long bolts toward the front floor of your overhead cupboard, could be under false floor of same. The lower underside will possibly be secured to mounting plate at back. Be sure to remove these screws otherwise you may bend your mounting plate.
Feb 15, 2012 | Sharp R-1874 Convection/Microwave Oven
Hi i have a Coleman 8000 series aircon in 2007 model Jayco Caravan we have just been away for 4 days and it was leaking water through the vents onto the floor what causes this does anay one know as it...
Please check drain tray is not blocked.And also check Evaporator coil for dust blocking. Clean drain tray,coil and air filter. Check fan motor speed. If less speed, replace capacitor.Thanks.
Feb 21, 2011 | Coleman Mach 15 Air Conditioner
My 02' Grand Caravan front A/C is not blowing in the front
Could be the fuse for the front blower motor, or worse the motor itself.
Choice A is easy and not expensive. Choice B could be somewhat pricey, or really pricey if the dash has to come out for blower removal/replacement.
Don
Apr 13, 2010 | 2002 Dodge Grand Caravan
How do you change the cabin filter on a 2005 caravan
have an 02 the cabin air filter under unit on passenger side next to hump in floor,open bottom door and pull filter down.about halfway down you will half to bend the filter a little to pull it all the way out. hope this helps.
Apr 04, 2010 | 2005 Dodge Caravan
Ihave 02 grand caravan sport 3.3 code p0204 i
Check the coil itself,or replace it.The e c m sends power to the coil,12 volts,but it also breaks the ground side of the coil to load it,to fire on time.
Jan 25, 2010 | 2001 Jeep Grand Cherokee
Brake pedal all the way to the floor...Possible abs module?
Im going to assume that a mechanic has already checked for the most simple causes like making sure the brakes have been bled. If the abs module is faulty it will default to just a no abs state, but that wont cause the pedal to go all the way to the floor. I agree that replacing the caliper is probably gonna fix the problem, but I might try to bleed the brakes first and see if that solves it first...
Jan 24, 2010 | 2001 Dodge Grand Caravan
How to take dash apart to get to the radio
The moulding around the radio removes quite easily. Remove the ashtray, 2 screws. Remove the slideout cupholder. 2 screws. The moulding around the radio pulls straight out. It has slideout or popout clips. Once that is removed, unscrew the 2 10 mm or philips screws that hold the radio in. Slide out the radio, another 10 mm ground screw on back, then unplug the antenna, 2 electrical connectors and that's it. I dont recommend an aftermarket radio without a schematic or someone that knows what they're doing. Like in the chiltons books, "reverse disassembly procedure to reassemble". Hope this helps
Oct 09, 2009 | 1995 Dodge Caravan
02 Dodge Caravan one headlight will only work at
i have seen this problem before..sounds like underhood fuseblock is bad..flip unit over and check connections..dealer part..hard to get at a wrecker's here..may not be where your located..
Apr 09, 2009 | 2002 Dodge Caravan
Miscellaneous Logo
65 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
