Question about Standard 1980 Fiat 124 Oe Replacement Air Inject Check Valve
How to replace convertible top - Standard 1980 Fiat 124 Oe Replacement Air Inject Check Valve
    Top Expert:
  • Standard Master
  • 44,254 Answers
Take to body shop and have them do it .
Posted on May 01, 2015
Fan on air cleaner blows out top but does not suck
If air is blowing out - it most assuredly is getting in. The area of the intake make be large enough for you to perceive air being sucked in.
Make sure ALL filters are clean. Remove and replace disposable filters or wash and replace permanent filters. Do this for pre-filters too. Then, try again.
Oct 23, 2015 | Hunter 30200 Air Cleaner Purifier Filter...
What type of refrigerant is R22 ?
R22 is the older version of refrigerant, discontinued several years ago as it was found to be an ozone depleting agent. It is no longer available for any type of commercial use. Was used in refrigerators, air conditioners, etc. The new type is R134a, and is available anywhere. Most systems can be converted to R134a without much modification, some of the more aged systems, just have to be replaced with a newer unit or appliance.
Aug 20, 2014 | Trane TFE235A9AH30 300-1800 CFM AIR...
New furnace, Water In Induction Motor, Yellow Flame
The problem is too much gas as opposed to not enough air. It is still running rich. Did you take into account the elevation of the location your furnace is installed at. The higher above sea level the less air that you have to aid in cumbustion. The condensation is from excess gas being cold and causing water to accumulate. Can you run it like this? Yes but it will cause issues with soot and carbon deposits. It will also cost you more money in the long run.
Dec 23, 2013 | Goodman Manufacturing Goodman GCH950453BX...
What hydraulic oil should i use for convertable top motor
You can use any hydraulic fluid. It is usually about the same as a 10 W oil
May 06, 2013 | AM Auto Parts 1996 to 1999 VW Cabrio Mass...
My fan running 110v how to convert in 220v
Use a stepdown transformer to reduce the 220v back to 110v. You can buy them on the internet for using 110v gear in 220v countries
Apr 13, 2012 | Air Purifiers
The blue light is flashing?
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 14, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Side by side refrigerator....Maytag
The cover where the parts are located is in the back of the freezer section, you will have to remove the screws and you will be able to gain access to all the parts.
Nov 23, 2009 | Air Purifiers
I have Ionic Breeze SI730. Won't turn on.
You could try some appliance repair shops. If you are able to solder the loosen wire , do so. but the ball-baering coming offf indicates a serious problem within the motor. Look in your yellow-pages for electric motor service. They could help replacing the baearing. But do not be surprised if you didn't get the bearing replaced. Those small appliances are meant for "disposable" use.
Oct 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Screw top stuck
Sit on the top, and pull on the handle very hard. It will pop off, and most likely not break.
Then you will need to take the nut off with some pliers, and glue it back into place.
Most likely some water got into your filter at some point, and it rusted. Making it nearly impossible to screw out. So when you turn the top it spins the nut instead of screwing out. Mostly due to the circular type nut that Honeywell poorly chose.
Oct 29, 2008 | Honeywell Enviracaire 12520 Air Purifier
Ionic Breeze Quatra
Check online to see if you can purchase just the replacement parts and fix it yourself. Chances are, however, you might be forced to send it to the manufacturer to get it repaired.
Check your local stores (WalMart, Target, etc) in the luggage area and get one of those power converters that you use when you travel to a different country. I wouldnt leave home without it. it pays for itself when you consider how much stuff you can literally destroy and cook off because the voltage is different than what it is here in the USA.
Jul 22, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Standard 1980 Fiat 124 Oe Replacement Air Inject Check Valve Logo
164 people viewed this question
Top Standard Air Purifiers Experts
Are you a Standard Air Purifier Expert? Answer questions, earn points and help others
