Question about Poulan Garden
How do you clean the gas out of my poulan pro 33cc gas trimmer.
    Top Expert:
  • Poulan Master
  • 43,020 Answers
Remove cap and invert it over a bucket .
Posted on May 01, 2015
  • 15 Answers
SOURCE: how do you change a head on a poulan pro trimmer
Try putting a wrench on the nut that is above the head to hold it steady. Then try turning the head off being aware that the stud the head spins on to has left handed thread on it.
Posted on Apr 23, 2009
  • 8 Answers
SOURCE: Poulan Pro Gas Trimmer Carb Problem...
try and adjust the fuel/oil mis screws
Posted on May 12, 2009
  • 376 Answers
SOURCE: Looking for the diagram for the gas tank for
You have two lines going into the tank, a small and a large one. The large one goes just inside the tank and connects to the top outlet just under the primer bulb. The smaller line has the fuel filter attached and lays on the bottom of the tank. The other end attaches to the lower outlet on the carb. Hope that explains it for you. Dwain
Posted on May 19, 2009
#1 Taper
  • 1040 Answers
SOURCE: How do you wind replacement line to the Poulan Pro
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Posted on Jul 03, 2009
  • 8 Answers
SOURCE: the pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Posted on Apr 27, 2010
I have a poulan pro link 33cc sting trimmer it runs for a while then it dies or I give it it wants to die out an bog down anyone know what to do
Fuel filter!
They are located in the gas tank.
Use a hook to grab the fuel line/tubing, there will be enough tubing to pull the filter out of the tank. Filter will be on end of tubing.
Replace it. Hope that helps you out.
Good luck.
look here...
May 19, 2015 | Poulan Garden
Spark plug gap for poulan weedeater
Go to the following site where you may well find parts needed
http://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/poulan/hedge-trimmers/pp2822-966513101-2011-03/engine
Jun 10, 2014 | Poulan Pro Ppb330 33cc Gas Line Grass Lawn...
Ppb339 wont stay running
Fuel issue, carb adjustment and/or carb rebuild.
Jun 01, 2014 | Poulan Pro PPB335 33cc 17" Gas Line Grass...
Won't start
Will probably have to rebuild carb, and replace fuel lines and fuel filter.
Nov 22, 2013 | Poulan Pro PPB335 33cc 17-Inch Gas Line...
Did not get an owners manual with my 33cc gastrimmer need to know the gas oil mixture .
40:1 = 3.2 oz of 2 stroke oil for every gallon of gas
Link to manual is below http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
May 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Where can I get a manual for a Poulan Pro 14" Gas Chainsaw 33CC P3314?
Sure! Click on "Get this Manual"
At:
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/p3314_p3314ws_p3314wsa_p3416_p3516pr_p4018wm_p4018wt_p3818av_p4018av_1.html
Sep 27, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Garden Logo
49 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
