Question about Philips 50PFP5332D 50 in. Plasma Television
Phillips TV makes a crackling noise then it shuts off
TV makes a crackling noise then it shuts down disconnected the power source then reapplied the power to it and it turned on for a couple of minutes and it did the same noise and it shut down ?
    President:
  • Philips Master
  • 749 Answers
Well if the power supply board alone is making the same then clearly the problem is in it.
I can't tell you remotely what makes the noise and why is it shutting down.
I've seen them make noise because of a shorted diode in the PFC circuit, because of a failed capacitor in the Vs or standby circuit, because of a cracked solder joint in some of the large transformers or because of a worn out filter capacitors. Oh, and because of a failing thermistor at the board's input, but that's usually accompanied with smoke and is easy to detect, plus it only happens once or at most twice.
If course it may as well be something else.
The best I can do is offer you to send the board to us for inspection and repair.
This should be the board and the repair service we offer for it:
http://www.coppelltvrepair.com/p/215/lj92-01511a-996510019427-power-supply-board-philips-50pfp5332d-service-repair
Hope that helps!
Posted on May 02, 2015
Westinghouse TV making crackling sound
I have had the same issue with a Westinghouse 50 inch LED TV. I believe it is not the power supply but the HDMI input. You can temporarily work around by plugging your primary source into the other HDMI. You may also get some relief by using the Westy remote, finding the TV menu, then selecting (Option) (Restore All). There may be an arcane procedure to reset the HDMI.
Jan 01, 2013 | Westinghouse Televison & Video
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to chesterpendilton@yahoo.com
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
How do i get my speaker to stop making loud sounds
Reduce the volume for sure, but if what you meant is some crackling noise then the power amplifier must be checked for malfunction. The failure can be a series of failures on the power amplifier , disconnect the input and confirm that it is an internal noise and not from any source.
Jan 21, 2011 | Bang and Olufsen Beocenter 9300 Shelf...
Tv turns on but makes an electric cracking sound and shuts off another one turns on then the screen wigs out and turns off with the power light flashing
Try to unplug tv from the power source for 2-5 minutes and if still have the crackling sound it means the tv needs to be fix. So check your tv's warranty and call the tv's manufacturer to have it fix or replaced.
Sep 09, 2010 | Philips 32PT6441/37 32" TV
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
Crackling noise on tv
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.When it's not able to provide power to the lamp it will flicker,cause the tv to shut on and off .You will need to replace it.Price varies from $40.00 up to $100.00 This procedure is fast and easy.Have a bless one!
Apr 02, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Wavey color lines at bottom of picture. Crackling noises coming from back bad picture
Howdy;
The "crackling noises" from the back is causing the picture to distort. 1) Either locate source of "noise" and correct or 2) Call a Service Company and get corrected. I would recommend that you DO NOT USE TV until this corrected. It may cause a fire inside your TV.
Good Luck, Big Irish.
Nov 22, 2009 | Televison & Video
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Crackling noise from tv
That crackling noise has nothing to do with the television and everything to do with your antenna. It is merely signal breakdown, when you get signal interference with analogue tv you get snow, with digital you get little squares on the screen and/or sound breaking and cutting in and out, get a licensed antenna repairer to come out check your signal strength as you may need a booster or your antenna could just be a few degrees off....
Dec 08, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Philips 50PFP5332D 50 in. Plasma Television Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
