Question about Ryobi Garden
My Ryobi cs 26 weed trimmer was running rough,and hard to start cleaned carb, replaced gas lines and spark plug. Now when i try to start it, gas comes out of air filter??
    Top Expert:
  • Ryobi Master
  • 42,945 Answers
You put hoses on wrong recheck how they are .
Posted on May 01, 2015
  • 20 Answers
SOURCE: Craftsman Wee trimmer will only run when tilted on its side.
its your flaot in your little carb
Posted on Mar 24, 2009
  • 8 Answers
SOURCE: replaced new gas line, new primer bulb, new
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Have you checked the spark plug?
Posted on May 20, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
  • 115 Answers
SOURCE: Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Posted on Jul 06, 2009
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Posted on Aug 02, 2009
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Can not get it started.
have you tried to replace the H T lead?
Jul 22, 2010 | Homelite Mighty Lite Lawn Trimmer
Aug 01, 2009 | Ryobi Garden
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Garden Logo
119 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
