Question about Garden
Why do my weed eater start but will cut off after starting
    Top Expert:
  • Garden Master
  • 46,460 Answers
Lack of fuel usually causes this to happen leave choke on a little longer .
Posted on May 01, 2015
Why does the weed eater not trim even though it spins?
it is getting hot from friction because you cannot tighten it so the head spins but everytime it hits a wed it tries to stop spinniing because it is slipping from the bolt not tightened. fix the bolt hole with a tap and put in a new bolt
Jul 14, 2015 | Troy-Bilt Troy-Built Gas String Trimmer...
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Why weed eater wont stay started
    • #1 - Change Fuel Filter
    • #2 - change or clean Spark Arrestor
    • #3 - Change or clean Spark Plug
    • #4 - Clean carburetor
    Order of importance, Start at #1 and work forward.
    Look here...
    Jul 22, 2014 | Echo Garden
    My weed eater starts but won't stay running. what
    Try a new spark plug.Thanks for asking and I hope it helps
    Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    I have weed eater model FX26SC it starts and when I put it to run the weed eater doesn't spin but is running
    Either the clutch is worn out or the flexible drive shaft is broken. Either repair is likely to cost almost as much as a new unit.
    May 16, 2010 | Garden
    My Ryobi weed eater loses power at working speed after 5 minutes.
    you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
    Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Sthil weed eater will not run when hot?
    you will need to replace you muffler so the machine can get rid of it's exhaust
    Jul 23, 2009 | Garden
    Weed eater starts, runs 5 min. then cuts off
    The gas cap may be clogged.
    The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
    You may also check the air breather, it may be dirty as well.
    Just let me know if you need further assistance.
    Jim
    Jun 28, 2009 | Poulan Pe550 Gas Edger
    My te 475 weed eater wont start
    Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
    May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
