Question about Garden
Why do weed eater constantly stops - Garden
    Top Expert:
  • Garden Master
  • 45,441 Answers
Do not know as we have not heard make /model / gas ,or electric .
Posted on May 01, 2015
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    Having a problem starting my Shindaiwa T22 Weed Eater.
    take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
    May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
    Ryobi weed eater head won't spin
    Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
    Apr 27, 2010 | Ryobi Garden
    Poulan ppb 250 weed eater, only runs with choke on,
    HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
    Sep 20, 2009 | Garden
    WEED EATER STRING
    you have the string in backwards, or the gear is not ingauged.
    Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    Poulan Weed Eater Trim Line Constantly Jams
    Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
    Jim
    Jun 13, 2009 | Poulan Garden
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
