Question about Bell F20 Cyclocomputer
Came outside, ********* circle on screen (in sun). Blocked for a minute, it cleared but then displayed all symbols.
I lost my accumulate miles, over 1560, and I'm stuck in KM, not miles, and can't get anything to adjust. Not certain of all functions as lost the manual. Help
How cose does mercury get to the sun
Mercury is the closest planet to the Sun. Its orbit around the Sun is very elliptical, like a stretched out circle, compared to those of the other planets. Mercury's distance from the Sun ranges from 28.6 million miles (46 million km) to 43.4 million miles (69.8 million km)
Mar 23, 2015 | Zazzle Planet Mercury Stamps
How to adjust screen brightness in samsung rv509 laptop
You should be able to check the function keys (F1-F12) and one of them should have a little symbol, it will look like a sun (circle with lines radiating out from the circumference) and a little up arrow, it will probably be right next to one with the sun and a little down arrow. Press the "Fn" key (right next to the left windows key) and hold it down, then tap the "sun up" key. That will raise your brightness.
If you want to raise it permanently, go into the Power Control Options in the Control Panel and find the setting for screen brightness.
Sep 12, 2011 | Samsung R580JBB2 Notebook
Programming Utilitech Item # 0192773
Go through the normal setup. Year, month, day, time, DST and the location (north, center, south).
Hit program and make sure all events are clear. Program the first (ON) event, press the TIME button and press /- (with the hour segment blinking) until you see the Sun/Moon symbol indicating the sunset time. Press PROG and program the (OFF) event. Press the /- buttons until you see the Sun/Moon symbol indicating the sunrise time.
Hitting resume clears events if you accidentally entered them.
Make sure you display shows AUTO and you're good to go.
Jul 29, 2010 | Hardware & Accessories
Can't change display or audio settings "block" symbol...
they did if you have the manual it will walk you through how to switch from store floor model to home useage
Jul 01, 2010 | Sharp LC46SB54U 46 in. LCD TV
My tom tom cant read where we are and it is indicating our position on a road which is 15 miles away.
it sounds like it lost the satellites.
take it outside in clear view of the open sky and restart it and let it outside for up to 30 minutes or untill it locates and locks on to the satellites again.
Oct 19, 2009 | Tomtom ONE GPS Receiver
97 land cruiser wet carpet passenger side . have blown clear sun roof drain vents ..air con is dripping ok pipe outside floor pan ...no coolant usage ..no smell to wet carpet ... dried carpet drove last...
Does the car have climate control air/con?If so,air/con may still be coming on at different times.I would double check the air/con drip tray.Sometimes it has 2 pipes if the tray has split levels.One may still be blocked.(Does the car have a built in fridge?)Hope this may help
Sep 05, 2009 | 1996 Toyota Land Cruiser
Cant feel heat using remote 6711A10010D
You need to ensure that the LCD displays a sun symbol. If this is not the case this can be corrected by using the button which has triangle, snowflake, sun and raindrop symbol, press until sun is on screen. Then set temperature.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Jul 08, 2009 | LG LSC121PMA Split System Air Conditioner
Dont know what symbol on remote is for heating for LG split system airconditioner
On mine, it's the symbol on the right-most one of 4; looks like a sun-symbol with several single lines emanating outward from the circle.
May 19, 2009 | LG LSC121PMA Split System Air Conditioner
I lost my manual and I'm just trying to find out what the symbols on the front panel mean. I'm particularly interested in knowing what is the difference between the sun and half-sun
The full sun symbol means full heat drying,, and the half sun symbol means half heat drying.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Dryers
Servise mode
different models use different display methods, if there is any sort of touch screen it will appear there in an alpha-numeric display
eg U4-2 or J3-2 etc.others just display symbols if there is no touch screen (symbols like a pyramid of dots for out of toner, crossed circle for drum end of life etc) some of those will display a number if you hold down the clear button or the stop button, depending on the model
there are probably 5 or 6 different diagnostic systems needing different entry modes...you will have to be very specific with both the code and the model number of the machine
Nov 29, 2007 | Office Equipment & Supplies
Bell F20 Cyclocomputer Logo
624 people viewed this question
Top Bell Cycling Experts
dante
Mark Wolfe
Donald Ayers-Marsh
Are you a Bell Cycling Expert? Answer questions, earn points and help others
