Question about OEM 2002 Mercedes S430 GPS Screen wms335957 220 Type; S430, S500, S600 and S55, player, Nav disc drive, ID 2208703589 Stockton, California
My passenger seat won't move. I'm looking for the fuse location
2003 passenger set no power is their a fuse or what worked fine a week ago ?
More then likely the seat motor has failed, check your owners manual for the fuse location but I suspect the seat fuses are ok.
Apr 20, 2017 | Seat Cars & Trucks
Can't get the drivers seat to move, could it be a fuse and where would that fuse be located?
Fuses are located on the drivers door jamb and in the engine compartment. See your manual. If the passenger seat is power and it works, then your problem is not a fuse but a switch.
Mar 21, 2014 | Oldsmobile Aurora Cars & Trucks
Why won't 2000 nissan maxima passenger seat go backward ?
try to look under the seat for coins that have fallen down and got stuck in the track. it happened to mine!
Apr 07, 2013 | 2002 Nissan Maxima
2009 Chevy Malibu power seat won't move
Check for a blowin fuse, Defective relay, Loose wires break in one of the wires, Switch could be shot, OR evan the motor has burn,t out,
Dec 06, 2012 | 2009 Chevrolet Malibu LTZ
Hello, We can't get the driver's seat to move back and forward, it just got in the position that it's in now and will not move, but the passenger seat will move. Someone said it's the fuse
If the seat is power, you may want to check the fuse first. You can find the location in your owners manual. If the fuse is good, you may have a bad seat motor. That should be taken care of by someone familiar with power seat carriage replacement.
Jul 04, 2011 | 2000 Lincoln Continental
The drivers side seat electrical does not work. Seat won't move, car was purchased without a manual. Where are the fuses for this?
The fuses are generally located in a panel under the drivers side of the dash. while you are under there. take a look under the drivers seat and you'll see the wires for the power to the seat. I have known firends who've unplugged their power options accidentally while shoving such as a flashlight under there, Just thought it may be helpful to think about, in the case that your fuses are all good.
Hope this helps
Good Luck and Happy Motoring
Respectfully
Jun 12, 2011 | 1996 Buick Park Avenue
I want to convert my 2008 Toyota Sienna XLE AWD from 7 passenger to 8 passenger. How do I do it?
I don't think you can. I owned a 07 EL 8 passenger, now i own a 08 EL 7 passenger and the floor hooks for the seats are located differently (the 8 passenger has an extra hook, if I remember correctly), so i don't think its possible, look at your manual and only shows how to move the seats.
Feb 26, 2010 | 2008 Toyota Sienna
The heated seats for the front driver and passenger don't work
yes maybe a fuse, also look under the seat and ensure the wire is connected they sometimes get caught when moving the seat back and forward and split against the metal seat base.
Jan 16, 2010 | 2007 Chrysler 300c AWD Sedan New Cars
Front drivers seat electric position button won't move seat back
Check the fuse. The fuse box is located on the passengers side at the side of the dashboard. Also check the fuses that are located under the hood. The location for fuses are in your car manual.
Feb 23, 2009 | 2000 Oldsmobile Intrigue
Seat motor
I got the same problem whit the Passenger Seat. After perform a Diagnosis to the Electrical system and confirm every thing was right (fuses and voltage on the harness going to the seat) , I had decided to remove the Seat, then disassemble the side panel where the Activation switch is located and I have found the problem was the button was worn.
The easiest solution could be replace the switch , in my case I was able to repair the button by opening it putting some Tin solder on one of the internal traces and replacing one damaged micro spring.
I would recommend to replace the switch.
Joe
Aug 15, 2008 | 1998 BMW Z3 Roadster
OEM 2002 Mercedes S430 GPS Screen wms335957 220 Type; S430, S500, S600 and S55, player, Nav disc drive, ID 2208703589 Stockton, California Logo
197 people viewed this question
Top OEM Computers & Internet Experts
David Payne
David Payne
David
David
Are you an OEM Computer and Internet Expert? Answer questions, earn points and help others
