Question about Home
Whatm doesa blinking FF mean? - Home
What does ff error mean
For LG A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
Jan 06, 2018 | Refrigerators
Error code for FF for KingAir air conditioner?
Error code FF means the outdoor DC motor fault.
first check the resistance value of the DC motor port, change the DC motor if short circuit.
Nov 08, 2016 | Refrigerators
What should I do? Freezer is not cooling, inside light is on, control panel is off temp shows blinking OF and FF
usually means low freon... (of) and evaporator fan failure. can you hear the fan running in the freezer portion?...
Jun 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What can I do? Freezer is not cooling, inside light is on. control panel is off, Temp shows blinking OF and FF
Might need a freon top up. If the compressor is functioning there may be in sufficient freon . This can be topped up. A repairman/technician can diagnose this fairly quickly
Jun 05, 2015 | Frigidaire Freezers
Code ff on portable electric heater. What does code ff mean
If its a Sunbeam you need to check the electric cord an make sure it is plugged into heater an wall socket well. Really need brand an model to help more.
Jan 27, 2015 | Refrigerators
8 e code
Most like it is a defrost sensor error in the FF section. On the back of your refrigerator there should be a schematic of what happens when there is an error...normal when performing the self test and all is ok is a reading of 88 88 Different parts of the 8 will blink depicting the error. For 88 88...if the last 8 is blinking the sections on the right side of the eight it looks like an E...but it is not.,..it is blinking an R1 b, or R1 c error. Looking at the chart R1 b is Sensor System in FF Compartment Errors, and R1c is Defrost Sensor Error in FF Compartment Errors.
I hope this clears things up as I see a lot of people say there panel is flashing 88 8Y, or 88 8E when actually it is just different parts of the 8 blinking.
Feb 20, 2014 | Samsung Refrigerators
I have an ep-8kta3+pro m/board. Occasionally it fails to start up and the LEDs are stuck on FF. What does the code FF mean?
FF mean kind for computer geeks Fatal Failure meaning the only solution is geting a new one thanks and good luck
Oct 20, 2009 | EPoX EP-8KTA3+ Pro Motherboard
FF flashing on the thermostat
Remove the tstat from all power sources for 3 or more hours to remove the short term memory and then reset the t-stat. The FF blinking doesn't affect the abilities of the unit.
Apr 02, 2009 | Carrier 38CKC060 Air Conditioner
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Home Logo
410 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
