When selecting programme and switching on machine, the electricity trips
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Earth leakage prob
Posted on May 02, 2015
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Jul 02, 2015 | Washing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
The washer hasnt run through its full spin the electric tripped so i dont how 2 start the programm again 2 finish the cyle
turn it on and select the spin cycle again if it trips again the moter has a fault and u will need to get this checked
Jul 29, 2009 | Washing Machines
My Bosch Classixx 1200 washer causes the household RCD to trip
The first thing I would recommend u do is to remove the motor and check the carbons for wear, Their should be at least 3mm of carbon showing, any less then u shud replace.
The other possibility is a faulty heater element, u cud try it with the element disconnected, if it does not trip then the element is faulty.
Plz rate my solution.
thanks.
Dec 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
De 73 tripping house electrics
NEED TO REMOVE AND CHECK WIRING ESPE THE HEATING ELE AND MOTOR WIRES AND LOOK @THE HEATING ELE INSIDE THE ENCLOSURE CLOSE
Dec 12, 2008 | Indesit 24 in. DE73 Evolution...
AM 110 washing machine - light not coming on and would not respond to programme
It sounds to me like you may have blown a fuse or tripped a breaker. If your washer uses a regular 110 volt outlet, you can try plugging in another electrical appliance of some sort to see if there is any power in the outlet. The only other possibility I can think of right now is possibly a fuse inside the machine.
Mar 02, 2008 | Hoover AAA160 Front Load Washer
My washing machine starts only when i select a cold wash.
If it's tripping breaker in house there is a short in unit. Check wires going to hot water valve for bare wires hitting metal. If wires are ok, replace inlet valve.
Nov 18, 2007 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
