Question about Garden
If you changed the fuel lines but the gas want come to bubble what should you do?
  • 1,169 Answers
To add to Ted's response:
Also check that you didn't reverse the lines at carburetor.
Posted on May 02, 2015
  • 3,519 Answers
Hi Daniel:
Double check that you replaced the lines correctly.
Routing is:
Fuel tank to
Carb to
Bubble pump to
Fuel tank
I have a BG55 blower when I try to prime it no gas come in bubble. I have made sure there nothing in gas line,and it skeet when I put a pin in the little hole, but no gas when u try to prime.
Apart from the bubble there is at least one non-return valve that could be stuck or not working because it is dry.
Could be removing the bubble and wetting everything thoroughly with fuel and quickly refitting it could kick-start it and make it work.
Sep 05, 2016 | Stihl Bg 55
I cannot get my primer to pump fuel from tank although I took compressor and blowed back thru fuel line to tank and I heard bubbles in tank.
If you are saying from the primer bulb..Regardless if you hear bubbles or not..you most likely have a cracked in the small line from the push bulb..that line calls for vacuum to pull gas from the tank into the carb..sometimes they get griddle and will develop cracks and lose the ability to pull vacuum...have them changed.should fix the problem not a hard or expensive job good luck..
Feb 23, 2015 | Garden
Why is there no gas in the bubble
look for cracks in the fuel line and make sure the filter is still on the end of the line inside the fuel tank
Sep 05, 2012 | Garden
Can't start and gas is not being pulled thru the filter. How do I test to make sure my fuel pump is working?
Pull the spark plug wire to make sure the engine doesn't start. First check the line from the gas tank to the pump. Disconnect the fuel line from the gas tank at the fuel pump. Take off your gas tank fill cap and using light air pressure, blow into the line to see if you get bubbles in the gas tank. Canned air for cleaning computers or compressed air at a very low setting work well for this. Do not use high pressure so you don't burst the line or blow it off a connection that's not easy to get at. If no bubbles come up in the tank, check the line and pickup area of the tank. If the line is clear, reconnect everything. Disconnect the fuel line at the carburator. Holding the end of the fuel line in a small jar, turn the motor over. If the pump is OK it should shoot gas into the jar. If not the pump should be replaced. If it does check your float and needle valve in the carburator bowl.
Mar 11, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Started 6 months ago - ran out of gas at 1/4 tank, figured gage was bad, added gas no problem. Now runs out of fuel at any level afterr it warms up. Changed out fuel pump on frame rail, fuel filter, coil,...
do a check on the fuel pump in the gas tank, else replace a section of fuel line near the throttle body with a clear plastic line, if yu see any air bubble that is your problem, then its a problem of where the air is getting in, a fuel line can leak air in with no fuel leaking out, connect a fuel guage to the system and monitor it at different speeds, could be the pressure valve is faulty, just giving you a few things else to check
Nov 29, 2010 | 1989 Ford F 150
How does a gasline bubble work,does it **** fuel through carby or push fuel into carby
The gas bubble is a primer. You push it 2 to 3 times to put fuel in the card before you start the motor.
May 27, 2010 | Craftsman 25cc Gas Line Trimmer
Stalls when giving gas
This symptom is usually lack of fuel to the engine, if you see bubbles in the fuel line replace all of the lines and the fuel filter (inside the tank). If there are no bubbles in the fuel lines the carburetor needs to be cleaned out or replaced.
May 26, 2010 | Craftsman 25cc Gas Line Trimmer
I just replaced a rotten fuel line on a craftsman 23cc weedeater, but when i push the primer bubble no gas goes in it. There are no holes i checked. Is there a anything else i could check for problems?
With your cover off so you can see the fuel line, see if you have any bubbles come through.If you see bubbles in the fuel line,when you pull starter rope,you have a line sucking air.
Aug 29, 2009 | Craftsman Garden
TB20CS gas trimmer, primmer bubble won't pull in gas
The carburator has a sereis of one way check valves that get cloged very easily.
If you remove the carburator and clean it out with a simple cleaning solution you should be able to clean it up.Do not use compressed air.
Aug 03, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
