Question about Craftsman 4-Cycle Mini Tiller
How to change fuel line? - Craftsman 4-Cycle Mini Tiller
    Master:
  • 969 Answers
Normally needle nose pliers to remove clamps on either end. Replace with same length and diameter line.
Posted on Feb 19, 2017
How 2 change the rubber hose fuel line on bottom of pump on 472 engine
Most likely your fuel system is about 150psi fuel pressure. So it is no ordinary rubber fuel line unless it is the old carbureted engine. If the low pressure system at a pump pressure of 4 to 5psi, then yes you can change with an ordinary rubber fuel resistant fuel line.
Apr 01, 2015 | Cars & Trucks
Changed front fuel lines , now vehicle won't start
why were the fuel lines changed? could have a air pocket depress the relief valve on the fuel rail and see if you are getting fuel this will also release the air in the lines
Mar 17, 2014 | 1993 Ford Aerostar Extended
Car not starting
The below will only be relevant if the engine ran properly before you changed the fuel line, so making an assumption on that. Not sure what you mean by "won't start fully". After replacing a fuel line, it could take a while for all the air to be purged from the fuel line. If this means the engine will fire, but stumbles and misses, and you are sure you have purged all the air from the fuel line, then you may have introduced contamination into the fuel system when you changed the fuel lines. If there is a fuel filter downstream of where you replaced the fuel lines, try replacing the fuel filter. If there is no filter downstream of the replaced fuel line, then the fuel injector could have caught the contamination. That scenario will be very time consuming to fix...R&R fuel injectors.
Oct 02, 2013 | Chrysler Concorde Cars & Trucks
How to change the filter and line from pump to filter
Should not change all the fuel line .Cut the bad line fuel and Measure the required distance . and take with you the bad line fuel to Advance Auto Parts . and ask him for new line and fuel filter and Link to connect the line fuel together , make sure no leak . good luck .
Nov 21, 2011 | Chevrolet Lumina Cars & Trucks
How do you change the inlet fuel line to the gas tank
There is no inlet fuel line,unless you're talking about a fuel line return from the pressure regulator? Or are you talking about the big hose between the fill cap and the tank?
If you're talking about a bad fuel line,is it plastic or steel? don-ohio
Nov 07, 2011 | 2002 Jaguar X-Type
How do you change a fuel line on a 2002 S10 blazer
First you need to unsrew the gas cap to relieve the pressure in the fuel system and than remove and replace the fuel line.
May 25, 2010 | 2002 Chevrolet Blazer
I want to change the fuel filter on my weedwacker
The fuel filter is in the fuel tank. Before removing make a sketch of where the fuel lines connect to. Empty the tank and use a flash light and look inside the fuel tank to see which line has the filter on it. There's a retainer on the fuel line up against the fuel tank on the outside. Use a small screwdriver to remove this retainer. It looks like a washer. Remove the fuel line from the carburetor and using needle nose pliers pull on the old filter and remove it from the filler hold with the fuel line still connected. You should use a new fuel line the same diameter as the old one. From the outside feed the fuel line through the hole. It will be tight. Push it through until you can get a hold of it through the filler hold. Put the filter on then pull the fuel line back. Pull until the filter is up against the fuel tank. Put the retainer on the line and while pulling the fuel line tight press the retainer up against the tank. Attach the end of the fuel line back on the carb.
May 05, 2010 | Garden
Where is the fuel pressure regulator on a 2003 oldsmobile alero?
There are 2 fuel lines connecting to the fuel injector rail. The larger line is the pressure line and the smaller line is the return line. The smaller line attaches to the fuel pressure regulator. You will notice that the regulator also has a vacuum line attached to it. If you are planning on changing it your self, let me know. There is a specific way to change it for safety reasons.
Let me know.
Regards,
Mar 10, 2009 | 2003 Oldsmobile Alero
Craftsman 4-Cycle Mini Tiller Logo
121 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
