Question about Lavazza Espresso Point Capsule Machine
Notice deformation of the capsules ,water also leak to the tray
Very little coffee drip frm capsule,, Defective capsules???? Thx Alex
    Habit-Forming:
  • Lavazza Expert
  • 147 Answers
Is it everytime little coffee,or sometimes?
If is everytime -you have to descale the machine,if just sometimes you have to cllean flowmeter,wich is on the back of machine.
Posted on May 02, 2015
Delonghi Nespresso Coffee Machine Model EN66 After years of great use our machine now has small drips from the main coffee/water spout after use.
Try running apple cider vinegar through it. A few times. This is a mild acid that will get rid of mineral deposits from water. I do this on my coffee maker. Run straight water a few times after to get rid of the vinegar taste.
Dec 10, 2016 | Cars & Trucks
Leaking water when not in use
possible of leaking internal pipe may need to change /or drip tray to full also cheak water tank and see if it leaks
Mar 28, 2016 | DeLonghi DE LONGHI EN95S M.CAFFE CAPSULE...
Nespresso xn 2003 - water comes through without a capsule but when a capsule is in place the water goes straight into the catch tray?
at the back of the capsule holder there is a metal that correspond
with the sensor sow your problem is the sensor is not finding the capsule holder at the and of the capsule holder do you see the magnit if not replace and try agian
Jul 08, 2014 | Krups Coffee Makers & Espresso Machines
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
Nespresso leaks coffee in capsule tray
check the gaskets or orings for cracks and replace if they look bad .perhaps a little lubricant is needed
Mar 19, 2013 | Coffee Makers & Espresso Machines
Capsule area is leaking
Perhaps capsule holder.
Look Inside on top of this capsule holder for a crack in molded plastic where water come in.
(I have replaced big "O" ring for nothing because the capsule holder is cracked on top).
Jul 04, 2012 | Nespresso Citiz C110
Why do Nespresso capsules squash?
the capsule must plop in at an angle, it it's straight it will crush and not work properly
Apr 18, 2012 | Coffee Makers & Espresso Machines
Can not remove capsule and lever stuck
I had a similar problem, and it was down to high pressure remaining in the machine preventing the lever from releasing. You can test this by pressing the capsule in the machine (which will be much more solid than normal).
To fix, all you need to do is make a hole in the stuck capsule. I did this by drilling a small hole in the side of the capsule.
That releases the pressure (and a little spurt of coffee!), and the lever will release.
Mar 10, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Coffee not dripping out of the machine
let it run without coffe tablets, if no water comes out probably the conducts are obstructed, may be calcium in the pipes...do water come out somewere else?...
Jan 08, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
271 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
