Question about White Sewing White 3032
Motor runs, but needle does not move
Sounds like motor starts turning, but needle does not respond. Needle moves easily when operated manually
    Top Expert:
  • White Sewing Master
  • 50,270 Answers
Belt broke possibly
Posted on May 01, 2015
Testimonial: "thanks, friend."
My machine is not running ,the motor sounds like it ok but the bobbin is not moving? Thank you It is a Singer 3116 Simple
if the motor is running and neither the needle or the hook are moving, then your motor belt has come off(the motor will sound like it is racing). If the needle is moving, but the hook is not, you may have a broken gear, or timing belt.
Dec 01, 2016 | Singer 3116 Simple
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
In sewing mode the motor turns but needle does not move. I have checked bobbin & upper thread - any help?
1. Try to turn the hand wheel. Does the needle move?
2. Make sure the center wheel on the hand crank is tight.
Try the hand wheel now. If you still don't have luck try this.
3. Loosen the center wheel on the hand wheel. There is a small screw on the center wheel on the front or side. Loosen it until it almost comes out.
4. Now tighten the center wheel. (clockwise) Does the needle move if you move the hand wheel? If it does you can tighten the small screw.
5. If this doesn't do the job you will have to take the cover to the motor off. The motor has a bolt to loosen. As you loosen the bolt you can move the motor until it tightens the belt and makes it aligned as well. Run the motor slowly with the foot pedal and adjust the motor until it operates at it's highest speed. Now tighten. Replace all covers.
6. The belt is sometimes in need of replacing but not usual. You will know when you take the panel off.
Apr 16, 2015 | Sewing Machines
Bernina 180 needle bar won't move up and down
This could be the needle bar clutch. Turn off machine. Unplug machine. Remove needle. Turn hand wheel in normal rotation 1/4 turn. Gently move needle bar up and down by hand you should feel a click and the needle bar will not move up and down easily now. Restart machine and test. If it works all is good. This is a result of the machine requiring professional attention. If you use basting stitches it will likely unclutch again.
Jun 15, 2014 | Bernina Sewing Machines
Turning wheel disconnected from motor?
I would try replacing the needle, as it may have got bent. I have had this happen and I was sure needle wasnt effected. when I changed needle it was fixed. The very tip of my old needle had a slight curve and wasnt connecting to correct spot on throat plate. make sure you have needle in highest position and that stitch selection in turned back to straight stitch.
Nov 08, 2013 | Brother Limited Edition LS2250PRW Project...
Needles Won't move
Sounds like a boss jam? Recalibrate to needle one, Reset for each mfg is different.
Cheers,
Embroidery Services
San Diego, CA
Sep 09, 2017 | Toyota Sewing Machines
Nothing works,but engine and belt run
the machine probably needs to be check to see why the needle & bobbin aren't working
May 28, 2012 | Singer 1507
The needle is stuck,not moving.its very hard and the motor makes a sound but needle does not move.
Refer to your manual and make sure the bobbin winding feature is disengaged.
Turn off the power and remove the needle and if there is fabric, remove it also.
Open the needle plate look for thread tangles.
After cleaning, turn the hand-wheel by hand to see if it moves the needle up and down.
If it does, press on the foot pedal to see if it is working.
Any of the above could be the problem.
Mar 01, 2010 | Kenmore Sewing Machines
Engine occasionally jams, still able to operate manually
It's been a while since this machines been oiled. try oiling both motor hole and needle operation.
Jan 24, 2009 | Singer Inspiration 4206
White Sewing White 3032 Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
