Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
How to hook up starter on toro z master - Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
How to remove starter on Toro Z master with kohler 26 HP engine?
First disconnect the battery. Then unhook the wires from the starter should be one or two wires. Remove the bolts from the starter two or three bolts.
Jul 24, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
I have a 2000 toro z-master 153 model 74175 serial no 200000420 . I just changed the engine from the FH680V to the FX730V all the wiring from the FH680V Fit the FX730V one problem is the starter from the...
Shawn , You need local help with ascertaining the function of the starter solenoid. I get the impression you have something wrongly wired in this area. Different systems have the solenoid operating a different way. Some have the operating wire from the start button grounded through the solenoid body, others use a wire to ground the sol. I think you have some thing going to ground on start up which is, luckily for you, blowing the fuses rather than torching the engine.
Get some help and a test meter to check out the wiring. It maybe as simple as a wrong connection and you can't see the wood for the trees?
May 19, 2014 | Toro Garden
Toro 74330 ztr wiring diagram
Could be several things. Starter sol hooked up wrong, key switch bad... well ok thats pretty much it, check those things then see what happens.
Dec 09, 2013 | Toro Lawnmower 20099 Mower Mowers Lawn
Is there a video on programming a toro lawn master II timer
I have found these timers to be the most difficult for a homeowner to master. I suggest going to Toro's web site and downloading the operating instructions.
Sep 30, 2013 | Toro 53805 Lawn Master II 4-Zone Landscape...
Toro timecutter starter
I think this is going to be like an automotive starter.
You will need to check 3 things.
The ring gear where the starter gear cranks the engine, the starter gear that engages the ring gear, and the overrunning clutch or bendix , which is the springy part that kicks the drive gear into the ring gear.
When you remove the starter from the engine, you will see the drive gear on the end of the starter that was inside the motor.
The drive gear is about the diameter of a half dollar or a silver dollar. it should not be chewed up, it should look like a good gear. Inside the place where the starter attaches, you should see a ring gear, with a flashlight, and those teeth should look good and not chewed up.
On the starter you removed, behind the drive gear and usually inside the starter is the bendix or overrunning clutch , which will push the drive gear into the ring gear when you crank the starter. These parts often fail every few years.
Some people fix them, most people replace the whole starter.
Be blessed.
May 05, 2013 | Toro 52" 27hp Z Master Zero Turn Lawn...
With Kawasaki engine, the starter motor spins, does not engage
The way them starters work is it is either engaged by a silonoid or a reverse plastic gear so when the starter is energized the gear comes up so. In other words u can buy a new starter or take it to a shop and have them rebuild it. If it is the plastic gear kind u can geta new gear for it
My battery wont charge even after i replaced the starter and voltiage regulater what else could it be
you need to check the actual alternator. The starter has nothing to do with the charging system so replacing that wouldn't solve a charging issue. Also make sure the battery is good
Jan 12, 2013 | Toro 52" 27hp Z Master Zero Turn Lawn...
Toro z master won't start
bypass the safety switches one at a time to test them
Sep 19, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
Pull start on my Toro snowthrower (snow master 20 - model #38020) it wont recoil itself. I removed the starter housing but can not figure out how to get the pulley and starter recoil spring out/off of the...
Its basically the same....best bet is to just buy the new pull start mechanism...they are pretty cheap, and they go bad on those units all the time.
Jan 12, 2010 | Toro Garden
Toro ground master starter not working, put new ing. fuses ok bat. is good
you need a starter solenoid. install one and you'll be up and running.
Jun 22, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
42 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
