Question about Polaroid Cameras
I replaced the batteries but when I try to turn the camera on the red light keeps flashing.
Camera hasn't been used for quite a while.
SOURCE: battery
I am having this problem as well
Posted on Jan 11, 2008
SOURCE: Battery charging
I had the same problem, called Casio, and -- like the first solution -- they'll send a battery.  So, folks, it's a manufacturer-originated problem and kudos to Casio for owning up to it (they admitted it on the phone) and for sending the solution, a replacement battery.
Posted on Jan 19, 2009
SOURCE: my casio ex-s770 camera does not charge
There was a recall on the batteries. Call customer support and they will send you a new one for free.
Posted on Jun 10, 2009
  • 7 Answers
SOURCE: Battery will not charge
I found this while searching to find an answer to solve my problem. It worked! Some say that it took them about 20 times... it took me about 7. Be patient and just keep trying! Hope this helps!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
  • 7 Answers
SOURCE: My Casio Exilim EX-S880 wont turn on. Battery is
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
ylu1 writes:
what i did was...
hope this helps.
Green light goes on when I turn camera on, but 3 red lights flash when I shoot & nothing happens. I tried changing multiple batteries, all alkaline. No luck yet. Any ideas?
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
Aug 05, 2015 | Fujifilm Instax MINI 7s Instant Film...
Pilot light not lighting on 420ex speedlite canon flash
This may seem dumb to ask but have you made sure all batteries are fresh (even new ones can be bad), they\'re inserted correctly observing polarity and the contacts are clean in the flash? (You can clean them using a clean, dry pencil eraser and a Q-Tip dipped lightly in alcohol.)
Also, try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Feb 28, 2013 | Canon Speedlite 420EX TTL Flash
Blinking red light
Is the battery door maybe not closing tightly, causing the metal area that touches the tips of the batteries to not be in close enough contact with them? This happened with my camera due to a cracked battery door, and until I can afford to replace it, I've put a rubberband around my camera over the little door to hold the batteries in tightly! Surprisingly, this is working for me! I know it's not an optimal fix, but thought I'd offer the suggestion. (You didn't say what make/model your camera is.)
Nov 20, 2012 | Cameras
Flashing red hand keeps popping up, when batteries
The flashing red light is warning you that the shutter speed will be too long for handholding the camera. Put the camera on a tripod or other stable surface, and/or use the flash.
Jun 05, 2009 | Nikon COOLPIX L18 Digital Camera
Won't turn on, only flashes a light
use rechargable minnimum 2500mah batteries -----solved
Nov 05, 2008 | Pentax Optio E60 Digital Camera
It wont turn on and there is a red flashing light
first check your batteries ,whether they are charged or not?and also try the hard reset method ,that is,remove the batteries and keep it removed for half an hour and then insert the battery and try again,it will help you
Aug 04, 2008 | Cameras
Will not turn on
mine does that when batterries are dead
Jun 04, 2008 | Kodak EasyShare C633 Digital Camera
Blackberry 7290 - Will not trun on
Unit is defective or the software needs to be reset/reflashed.
- J.
Mar 12, 2008 | RIM BlackBerry 7290
Cameras Logo
42 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
