Question about Garden
If solution takes 6-oz per gallon and my contanor is o.29 gallons how many oz do i put in?
  • 352 Answers
1.8 oz
Posted on May 01, 2015
Testimonial: "thank man i know guitars but not numbers you made my day art."
If you put 1\4 cup of liquid in 1 gallon, how much would you put in 2 cups?
2 cups = 1/8 gallon
1/4 cup = 2 oz.
You need 1/4 oz. liquid per 2 cups of water
= 1 1/2 teaspoons
May 12, 2017 | Kitchen Appliances - Others
WHAT IS THE OIL TO GAS MIXTURE IN OIL TO GALLONS
Mixing
RatioGAS:OIL UNITED STATESOIL per 1 U.S. GALLON Gasoline
(128 oz.) *INTERNATIONALOIL per 1 IMPERIAL GALLON Gasoline
(160 oz.) *INTERNATIONALOIL per 1 LITER Gasoline
(metric) 32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
May 04, 2015 | Garden
How much oil per gallon of gas in a 50 to 1 mixture
2.56 oz of oil per gallon is the exact amount. Dump 3 oz. of oil in a gallon gas can and fill it up. Then mark the can so you don't mix it up with lawn mower gas.
Sep 24, 2014 | Garden
72in x 29in x 24in how many gallons calculator
72 x 29 x 24 = 50,112 cubic inches / 1728* = 29 cubic feet. There are 7.48 gallons per cubic foot, so the tank is actually 216.92 gallons, assuming the dimensions given are inside measurements. I hope you have a strong stand and floor because the water alone weighs 1735.36 pounds (8 pounds per gallon).
*12 x 12 x 12 = 1728 (cubic inches to cubic feet conversion)
Jul 17, 2014 | Aqueon All Glass Aquarium Co. 210 Gallon...
I need to know How much roundup per gallon of water. Also, can I mix Krovar with it and if so how much per gallon?
I use 3 oz. of Roundup to every gallon of water and it kills even the local star thistle. They can be used together with the Krovar ratio at 2.4 oz. per gallon.
Mar 27, 2011 | Roundup "" Weed & Grass Killer
I have the cocentrated roundup, how much per gallon of water for killing simple weeds
3 oz per gallon if the active ingredient Glyphosate-(says on front label) is 18% which is what most rounup is unless you get the super conc,etc...-----What I would do if i were yoiu is go to wal mart and buy their brand-ELIMINATOR-it has Glyphosate at 41%-same exact thing and cheaper.Use 2 oz/gallon water for great results.Buy the 16 0z bottle for about $8.00,that will make 8 gallons which will last a homeowner a long long time-probably 3-6 months.---rounup at 3 oz/gallon will work well also if youve already got it.Only spray what you want to kill.try not to miss! Weeds will start yellowing in about 3-5 days and then gradually die back at about 7-10 days.you'll need a few hours of no rain or watering to wash it off.Good luck!
Oct 22, 2009 | Roundup "" Weed & Grass Killer
HOW MUCH ROUNDUP TO GALLON OF WATER
regular concentrate 6 fl. oz per gallon
super concentrate 2.5 fl oz per gallon
May 22, 2009 | Roundup "" Weed & Grass Killer
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Garden Logo
914 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
