Question about Garden
Where does the spring to tighten belt connect
Spring came loose
    Top Expert:
  • Garden Master
  • 49,974 Answers
The spring will be connected between the idler pulley and a mount hole on the body frame
Posted on May 02, 2015
Deck belt loose ,how to adjust tension to make tighter
Not sure what type mower is but as long as the tensioner is moving to tighten the belt then you will need to replace the belt.Most tensioners have a spring attached to them make sure you did not lose a spring or the tensioner is not stuck and going to full depth before you replace the belt.
Apr 10, 2016 | Garden
How do I tighten drive belt on a LT2000 craftsman mower
you don't. you replace it or find out why it's loose. could have a broken tension spring.
Oct 08, 2014 | Garden
Is it possible to tighten a loose belt on my cub cadet RZT-54 ZERO TURN RIDER.model number 17AFCACK009
HI,
I assume you are reffering to the mower deck pulley...however, the belt that drives the two hydraulic motors work the same way as deck pulley system.
First, there is no manual adjustment on the pulley system. Rather there is a spring loaded pivot arm to which an idle pulley is fastened to. The spring pulls the pivot arm in such a way the it forces the idle pulley to keep the belt tight at all times. The same setup is used on the ground drive belt.
Sometimes these springs become disconnected or break so that no tension is placed on the belt to keep it tight.
Check the tensioner spring to ensure that it is connected properly and applying tension to the belt. Otherwise, you may have the incorrect belt installed, the belt is routed incorrectly or the belt may be stretched out and need replacing.
Here is a diagram to clarify, the spring is the dark black item;
Here is a link to a large diagram that is easier to read;
Lawn Mower Parts Small Engine Parts Much More PartsTree com Briggs MTD...
Jul 14, 2014 | Garden
Belt not turning
the pulley that the belt runs in may be loose-does it turn with the saft,or there may be a belt tensioner that is not tightening the belt-the tensioner is a pulley that has a spring connected to it-does the belt feel tight-cheers Denny
Oct 26, 2013 | Garden
The lawn mower belt is to loose how do you tighten it
You don't tighten the belt, there is a idler pulley it's between the motor pulley and the blade pulley where the chute is.
This has a spring that keep tension on the belt, so either the spring is bad, or see if there is another slot for the spring to make it pull more, or you have the belt routing on wrong.
Your manual should show the belt track.
If you can't move the spring and the belt is correct, get a new tension spring.
And clean off that deck, LOL
Apr 14, 2013 | Garden
How do i tighten the timing belt tension on a 1999 dodge stratus
The belt tensioner is not adjustable. To loosen a tensioner you would swivel the belt tensioner away from the belt with a long flex wrench or ratchet and to tighten the belt you would let the spring in the tensioner move the swivel back into the tight position. An internal spring tightens the tensioner pulley against the belt. You will need to get a smaller belt or replace the tensioner if the belt is "too loose" after you swivel it back into the tight position against the belt and release pressure.
Oct 19, 2012 | 1999 Dodge Stratus
Getting a 'squealing' noise from the engine all the time. What is the cause likely to be??
Depending on the model it could be a belt alignment problem, loose belt or bad bearing in a pulley. If the squeal gets louder if you spray water in the area of the pulley it is most likely a loose belt. I would start by looking at the belt itself first then spray WD-40 in the bearing area of the Idler pulley and tensioning pulley. If the WD-40 works the problem is a bad bearing. Otherwise it is again, most likely, a loose belt. As a final check you can spray belt dressing on the belt and if the squeal goes away then it is your belt being loose. This could be caused by a belt being stretched over time or a tensioner not working correctly due to a weak spring, if equipped with spring loaded tensioner. If it doesn't have a spring loaded tensioner then you may just need to tighten the belt by adjusting it.
Oct 12, 2010 | Chrysler Voyager Cars & Trucks
Looking for timing mark's for a 1997 camry with a 2.2 4cyl motor?
You find the timing marks on the picture below.
Removal
Remove auxiliary 1. drive belts.
2. Support engine.
Remove:
Engine mounting and bracket.
Timing belt upper cover [1].
3.
4. Turn crankshaft clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Remove:
Crankshaft pulley bolt [4].
Crankshaft pulley [5]. Use tool No.09213-60017.
5.
6. Ensure timing marks aligned [2] & [3].
7. Slacken tensioner bolt [6]. Move tensioner away from belt and lightly tighten bolt.
Remove:
Timing belt lower cover [7].
Crankshaft sprocket guide washer [9].
Timing belt.
Tensioner pulley.
Installation
Installation
1. Check tensioner pulley for smooth operation.
2. Check free length of tensioner spring is 46,0 mm [8]. Replace spring if necessary.
3. Fit tensioner and spring. Ensure spring is connected correctly.
4. tighten bolt [6].
5. Ensure timing marks aligned [2] & [3].
6. Fit timing belt. Ensure belt is taut between sprockets.
Install:
7.
8. Slacken tensioner bolt 1/2 turn [6].
9. Turn crankshaft two turns clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Turn crankshaft slowly 1 7/8 turns clockwise until crankshaft pulley timing mark [3] aligned with 45° BTDC mark [10] on
timing belt lower cover [7].
10.
11. Tighten tensioner bolt [6]. Tightening torque: 42 Nm.
12. Install components in reverse order of removal.
13. Tighten crankshaft pulley bolt [4]. Tightening torque: 108 Nm.
Manufacturer: Toyota
Jun 25, 2010 | 1997 Toyota Camry
The belt on my Chamberlain Whisper Drive dipping
Where the belt attaches to the trolley carriage which attaches to the door there is a black adjustment nut with a spring on it. Tighten it up more by turning it clockwise until the belt tightens up. The belt will droop a little when the door is all the way shut normally but should not during operation. If you tighten it up too much the belt will slap on the rail during operation. Make sure the spring is set on the adjustment screw too. This holds the belt tight over time. Thanks BB
May 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Tighten belts on my Yard machine ride on lawn mower
There is rarely any adjustment to tighten the belts on a riding mower. The belts are tensioned by an idler pulley which is controlled by a idler pulley spring. Almost all riding mower belts must be accurate to the hundredth of an inch or no less than accurate to 1/8th inch. It is very rare for a belt to be in full inch increments. This is why automotive or general purpose belts will not work on a riding mower. I know it is tempting to try to get by with a $10 belt rather than spending $35 or more for the correct belt. Trust me, you will only waste your money trying to get by with the inferior belts. Riding mower belts and extra heavy duty and generally will not stretch at all. Generally they will have 5 or more strands of a Kevlar type material so that stretching is virtually non existent. If the belt will not tighten then it is most likely not the correct belt. If the belt is in fact the proper belt and still is too loose, then you should look for pulley wear or weak tension springs. Metal pulleys do wear and tension spring do loose tension.
Sep 12, 2009 | Mtd Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
