Question about RCA Televison & Video
.I have 60 inch rca guide plus big screen tv control buttons don't work correctly
    Novelist:
    Habit-Forming:
  • 97 Answers
Replace the batteries.....use the matching process in your manual to make sure the controller and tv are matched up....check the tv settings by using your buttons on the tv...to make sure it hasn't been set to function manually...and not to respond to any remote controls....replace the remote controller....make sure the receiver eye or sound collection area of your tv is not covered by a drape or decoration of some sort...and clear and free of obstacles to communicate with the remote controller.....make sure the tv and cable box are correctly plugged into the electrical receptacle and to each other.....you may have to program your remote control to control your cable box too...instructions in your manual....or call the cable company and they will set your cable box controller to control your tv ......step by step over the phone.....it could be a high number of other things...like your neighbors remote interfering or the hamm radio guy down the street interfering.....but there are a few basic things to check out before calling a tv repair guy to come and get you working.
Good luck and I hope I was some help.
Posted on May 01, 2015
SOURCE: Guide Plus
When the guide is on scroll to the right until you see setup then scroll down to review options. There you should be able to turn the guide off. Hope this helps.
Posted on Oct 05, 2007
android1
  • 5 Answers
SOURCE: RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Posted on Nov 21, 2007
SOURCE: RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Posted on Feb 23, 2008
SOURCE: rca tv f27628
http://sci.tech-archive.net/Archive/sci.electronics.repair/2006-12/msg01203.html
Turn on the TV
using original remote:
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu)
Select option 1 (TV Guide Plus Setup)
Find the MENU, GO BACK and Input button on your remote
Press the MENU Button then immediately:
Press the GO BACK button then immediately:
Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Posted on Jun 23, 2008
  • 245 Answers
Remove your zip code, I had the same problem, when I removed the zip code it went away.
Posted on Jun 24, 2009
F36665
Found this on page 55 of user manual. Hope it helps.
Problem:
Every time I turn on the TV, the Guide is on the screen
Solution:
The GUIDE Plus+ system automatically appears on the screen when you use the TV button on the remote to turn on the TV. You
can turn off this feature by pressing GUIDE on your remote control and then select the Menu bar. Press the right arrow button to
select Setup. Choose Review options and select OFF.
Mar 07, 2013 | RCA F32650 32" TV
I bought a 27 inch tv in 2002 now the tv guide
Here is a whole forum discussing this.
http://forum.ecoustics.com/bbs/messages/2/138384.html
It sounds like you need to reset your local zip code to 99999 then unplug the TV for at least 12 hours. Then plug it back in, reset to your real local zip code and go through the guide setup menus.
Dec 24, 2009 | RCA F27442 27" TV
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
Our TV is stuck on a guide plus screen
i actually dont know what that is...mindboggling, right? call your tv company.
Jun 29, 2009 | RCA R52WH73 Projection Television
I can not get my tv to work with dish network
The RCA guide will not work with the dish remote. You can get the guide to close if you press the White TV button then press cancel. Remember to press the SAT button after you close the guide.
Nov 19, 2008 | RCA 32F531T 32" TV
Tv repair
usuallt that model can have issues with the flyback going out without warning. Go to this link and leave them an email indicating your model number and symptom they will be able to help you out they have alot of experience with RCA products
http://servicemanuals.vstore.ca/
May 07, 2008 | RCA D61W20 61" Rear Projection Television
Hannspree 23 inch TV
You can use any RCA universal remote and then program per the users guide or use the website below to find the codes:
http://remotefinder.rca.com/default.aspx?site=rca
Hope this helps!
Apr 08, 2008 | RCA RCR450 Remote Control
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
RCA F32450 TV
Question?
Answer:
Option A:
Select Setup.
Select Options.
Select Off.
Option B:
Select Off.
Option C:
Select Off.
Oct 27, 2007 | RCA F32450 32" TV
Televison & Video Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
