Question about Fellowes Office Equipment & Supplies
Why doesn't my Fellowes P600C-2 work?
It just doesn't work at all. No sounds, nada, zero
  • Jo Burns May 04, 2015
    I called Fellowes and there is a very thin slot when you turn the motor over and a slot that will fit into the basket. Line them up and press reverse. It should work if everything else is lined up and plugged in. Mine hasn't worked for 9 yrs. prior. Works great now!
    Top Expert:
  • Fellowes Master
  • 51,186 Answers
No power to the outlet perhaps .
Posted on May 04, 2015
    Top Expert:
  • 10,875 Answers
Push the reset button on the plug,perhaps
3 Suggested Answers
SOURCE: Fellowes P600C-2 Motor runs in reverse, but not forward
Take it apart and clean the switch with compressed air.
Be careful when you put it back together that you don't allow the wires to touch the fan.
You also have to make certain that the small plastic teeth that seperate when you feed paper are aligned properly.
Good Luck
Posted on Apr 04, 2009
  • 4 Answers
SOURCE: My Fellowes p600c-2 shredder will only run in
Never mind providing help, I fixed it myself. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Posted on Jan 18, 2010
Testimonial: "This solution worked for me."
We have a p600c-2 shredder and it will go in reverse, but it wont work in forwards. we have taken it apart, and we think the problem is the little switch inside. please help?
I had the same problem with my shredder. I removed 6 screws and the cover of the on/off switch. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism so it operated freely and reassembled the shredder. Hopefully this will work for you also.
Dec 04, 2010 | Fellowes P600C-2 Shredder
Reverse works fine, but I cannot get it to accept new paper to shred
Your Fellowes p600c-2 shredderappears to have the same problem I had, it would run in reverse but would not shred new paper. I removed the 6 screws that are visible on the top assembly, but could not get the top assembly to come apart. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Oct 01, 2010 | Fellowes P600C-2 Shredder
My Fellowes p600c-2 shredder will only run in reverse. I've blown compressed air on the switch and pushed on it with a toothpick but neither method worked. I removed 6 screws and the cover of the on/off...
Jan 17, 2010 | Fellowes P600C-2 Shredder
Missing wastebasket to Fellowes Shredder
I have a P600C-2 wastebasket - and the unit only runs in reverse. We need to put our two pieces together!
Mar 08, 2009 | Fellowes P600C-2 Shredder
Shredder no longer cuts out after 1 sheet disposal
no longer shreds after one sheet ? or no longer turns off after it finishes one sheet?
unplug unit open it up
clean it out with compressed air and check the switch inside make sure the lil metal lever is not bent , also test the switch with a meter
Oct 21, 2008 | Fellowes P600C-2 Shredder
Micro wave does not work EM-Z2100GS
First you check the fuse at the out put of highvoltage of the transformer. If the fuse is ok, replace the magnetron.
Feb 28, 2008 | Sanyo EM-Z2100GS Microwave Oven
Shredder no longer runs
Fellowes Customer Service is the best in the business call them at 1-800-945-4545
Dec 06, 2007 | Fellowes P600C-2 Shredder
On mine a tooth broke from a drive gear. I am trying to find somewhere where I can replace this part.
Oct 25, 2007 | Fellowes P600C-2 Shredder
Motor runs both forward and reverse, but cutters don't turn
How about a hidden 7th screw? If you look at the sticker on the underside where the bar code is you may see a dimple like there is a hollow space under it. If you can't see it, rub your finger over it to find the hole. Just stick your phillips screw driver through the sticker to get access to this last screw. As for the motor working both directions but the cutter doesn't turn it is most likely a broken nylon cog on the drive gears within the white plastic housing at the end of the shredder. There are 3 or 4 gears - all nylon (plastic), my unit had one tooth completely broken off and the one next to it was worn. I am looking into finding parts but I'm not having any luck so far with local service centres. I have a call into the fellowes main 1-800 number to see if they can help. On reviews I have seen this is a common problem. One reviewer was told they use nylon to reduce noise, but of course it isn't going to last long, especially if you ever jam. Nice metal cutters but the weak link is the drive gears that you can't see.
Oct 16, 2006 | Fellowes P600C-2 Shredder
269 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
