Canon EOS 500D EOS Rebel T1i Digital Camera with 1855mm and 55250mm lenses Logo
Joe Strickland Posted on May 01, 2015
How do I take time laps photos - Canon EOS 500D EOS Rebel T1i Digital Camera with 1855mm and 55250mm lenses
Tom Bobolts
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on May 12, 2015
Tom Bobolts
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1792
Points
9
This comes down to a couple basic things: careful planned and execution of your plan.
  1. Figure out what you what you photo and what the best way to capture the event will be. You're going to want to use a tripod to keep the camera in the same position for the duration of the event.
  2. Figure out how often you need the camera to take a photo. If the event is short like 1 minute, you're going to want to take more photos more frequently than if the event is one hour long.
  3. Position the camera and start taking photos. There is no magic "time lapse" setting on cameras so you're going to have to stick around and press the shutter based on the schedule you worked out.
  4. Grab your favorite movie editing program and edit them all together. Play around with how long you show each photo to control the speed of the time lapse effect.
  5. Export and enjoy!
How to download photos from phone to lap top ?
If the phone is recognised as a usb drive on the laptop (you may have to enable usb mode on the phone) then usually most pictures are located under a folder named "DCIM"
what model LG phone?
9answers
No watch instructions
- CHARACTERISTICS
1. Stopwatch: Measures up to 9 hours, 59 minutes,
59 seconds and 99 with 1 ¤ 100 second readout.
• Lap time measurement: Up to 9 lap times
can be measured. The lap time difference and
the fastest lap time are calculated and displayed
during the measurement.
2. Time/calendar display: Hour, minutes, seconds,
month, date and day of the week.
• Automatic calendar adjustment: Calendar
adjusts automatically for odd and even months
including February of leap years, but not for
February of common years.
• Time indication: Changeover between 12-
and 24-hour indications is possible.
3. Daily alarm: The alarm can be set to ring on a
24-hour basis.
4. Dual time: Time of a different time zone can be
set and displayed.
5. Stroke function: The watch can be set to beep
at a selected rate to serve as a pacemaker in
jogging, etc.
6. Countdown timer: Up to 9 hours 59 minutes
and 59 seconds can be set in seconds.
• “Lap time” refers to an elapsed time required to
cover a given section of the whole distance.
1. At the start of the activity, depress button “D” to
start the stopwatch.
2. At the end of the first lap, depress button “A”.
The first lap time and lap number are displayed,
though the second lap time is being measured
internally.
3. Depress button “A” to release the lap time before
the end of the second lap. The first lap time and
lap number disappear, and the measurement in
progress and “0” are displayed in place of the lap
time and lap number, respectively.
4. At the end of the second lap, depress button “A”.
The second lap time and lap number are displayed,
though the third lap time is being measured
internally.
5. Measurement and release of the lap time can be
repeated by depressing button “A”.
6. At the end of the activity, follow either of the two
methods below.
a. To display the final lap time, depress button
“A”. Then, depress button “A” to release the
lap time, and depress button “D” to stop the
measurement.
* The time displayed when button “D” is depressed
is not the total elapsed time of the
activity, that is, the time that elapsed from
the start until the end of the activity but the
time that elapsed from the start until the
stop of the measurement.
b. To display the total elapsed time of the activity,
depress button “D” to stop the measurement.
7. Depress button “B” to reset the stopwatch.
Stopwatch operation
Depress button “C” to show the stopwatch display.
Start Stop Restart Stop Reset
Accumulate repeatedly by
depressing button “D”.
Accumulated elapsed time measurement
D D D D B
Notes:
1. When a lap time measured is the fastest among
the lap times previously measured, a short beep
rings to signal that the memory has been updated
with the new fastest lap time.
2. The lap number counts up to “9”. After “9”, the
number returns to “1”.
• While a lap time is being displayed, depress button
“B”. With each depression of the button, the
difference between the displayed lap time and the
previous lap time is displayed in the following
order.
Latest lap time ® Lap time difference
Fastest lap time ¬
The selection of the display can be made in the
following order with each depression of button “C”.
* A flashing display mark indicates that the corresponding
function is in use.
- HOW TO USE THE STOPWATCH
• The stopwatch can measure up to 9 hours, 59
minutes, 59 seconds and 99 in 1¤ 100 seconds.
* Even if the stopwatch display is changed to another
while the measurement is in progress, it continues
counting properly. After the stopwatch is used,
however, be sure to reset it as the battery energy
is consumed enormously to shorten the battery
life.
Stopwatch display mark
Stopwatch operation
internally.
internally.
methods below.
measurement.
Notes:
Lap time difference and the fastest lap time
order.
• The lap time difference is displayed without a plus
or minus sign. Instead, the lap number of the
faster lap time is always displayed at the right of
the “–” mark.
Ex.)
Notes: 1. While the measurement in progress is shown
on the display, the lap time difference
and the fastest lap time cannot be shown
by depressing button“B”.
2. While the latest lap time, lap time difference
or the fastest lap time is shown on
the display, the display cannot be changed
to another by depressing button “C”.
* With each depression of button “A”, month and day
are displayed alternately.
* With each depression of button “D”, the display
changes over between the 12- and 24-hour indications.
1. Depress button “C” to show the time/calendar
display.
2. Depress button “B” to show the time/calendar
setting display. The second digits start flashing.
3. Selection of the digits to be adjusted (flashing)
is made in the following order by depressing
button “D”.
4. Depress button “A” to set the flashing digits.
One digit is advanced with each depression of
button “A”. Digits except seconds move quickly
by keeping button “A” depressed.
5. After all the adjustments are completed, depress
button “C” to return to the time/calendar display.
Seconds setting
When the seconds digits are flashing, depress button
“A” in accordance with a time signal. The seconds
are reset to “00” and start immediately.
Note: When setting the hour digits in the 12-hour
indication, check that AM/PM is properly
set. Only “PM” is displayed and there is no
indication for the AM setting. In the 24-
hour indication, there is no indication.
Date does not displayed on printed image
in the camera setup menu you have to have the time and date stamp turned on before you take the picture. Once you turn this feature on all of your photo will have time and date stamps. unless you turn it off.hope this helps
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
