Question about Panasonic VIERA TC-L32C3 32 in. TV
I changed the power-board and still no power. I had the cord checked and it's OK !!!
    Master:
  • Panasonic Master
  • 993 Answers
Check = power on switch
Posted on May 02, 2015
Won't power up or light up
1. Change power cord.
2. If Power cord is ok then Internal circuit board is damaged.
3. If circuit board fault then you should consider to television technician.
Nov 17, 2013 | Proscan 32LA30Q Television
Samsung j843 wont turn on
Check your breaker box... If not there I would check the cord to see if a powersurge damaged the cord or worse the machine utself.
Jul 15, 2012 | Samsung Washing Machines
Hitachi LCD TV looks like no power but power cord checks good
Hello
Eventhough the fuses and power cord os good, and there is no power light on the panel board, means the power board do not get power to it. Check an other power outlet point first. If it does not help you, soethnig wring with the power regulator baord. Normally, these board are irreparable, and replacement should be done as card basis. OK.
Feb 07, 2012 | Televison & Video
Wharfedale LCD2710HDAF no power to tv, checked cable and changed fuse a few times, new power lead? or is this a common problem?
Hi.
The power cord must be checked using a multimeter. The test is done reading impedance (ohms) between plug's prongs and contacts to TV power board.
If the power cord is OK and there is no power, then the problem is the power board inside the TV.
Regards.
Ginko.
Dec 04, 2011 | Televison & Video
Turned my sanyo dp42410 off last nignt and now it wont turn on no led light on he front nothing
Good day!
The problem of your TV is on the power supply.
Please follow this procedure for D.I.Y troubleshooting.
  1. Remove all screws at the back.Open the cover.
  2. Power ON the TV.Check the input voltage of power supply from the cord.If supply form the power cord replace it.
  3. If you have voltage supply from the cord.Check output voltage form the power supply board and for sure you have no supply on it because the indicator didn't lights up.
  4. Check your power supply board such as fuse if busted,power transistor and diodes if shorted,open/change value resistor and leak/bulge on top capacitor.
  5. If you found that replace it and try to power it on again.Then check the output voltage such as 5vdc for the system board,12vdc for the sounds and 24vdc for the inverter.
  6. If you got that 3 supplies your TV is OK.
Note:If this procedure is not fix your problem it means the power supply got a major trouble and not for D.I.Y..I suggest to you as a technician to buy a new power supply board or give to the qualified technician.
I hope this solution will be helpful.Thank you very much and good luck.
Apr 20, 2011 | Sanyo 42 in. LCD TV
Have lg tv model 26ld350 and will not power on. Have checked outlet and power cord and they are ok. Does this tv have a fuse? Appreciate any assistance.
Yes,the power supply board have a fuse near the edge of the board.That the board,where the power a/c cord plug into it.
Mar 25, 2011 | LG 26LD350 26 in. TV
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
Tv turns off and dont want to turn on again
check outlet power by connect other device, check power cord if OK check then unplug tv and open the back cover and check power filter fuse power filter is the one that you hooked power cord if OK check power supply board fuses if OK check the power supply board for bad blown components .good luck
Apr 29, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Won't turn on power cord good
is there red light on if yes check two boards the audio board and the power supply board for any blown components ,usually first check power filter where you connect your cord in to look for bad fuse if OK then look at the power supply if there is green light there then check audio board and power board. good luck
Apr 28, 2010 | Protron PLTV3250 32 in. LCD Television
Kenmore dishwasher... filled up with water and its lights went off.. no buttons work acts like no power. check the house fuse box - ok ... check the 2 door switch - ok .. checked the thermal fuse - ok ...
Did you check power to the unit? Double check the common and grounds. When servicing I will disconect(unplug from wall) power to the unit. Is it pluged in? Use another outlet(the outlet under the sink may be wired thru a switch for a disposer)even if you need an extension cord. Hope this helps.
Nov 12, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Panasonic VIERA TC-L32C3 32 in. TV Logo
71 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
