Question about Garden
Pull the starter cord on my leaf blower I hear grinding and it won't start
  • 3,519 Answers
Hi Mindy:
What happened before it died?
Is it possible that it is a 2 cycle motor and that straight gas got used?
I'd be concerned about scored cylinder. This can be checked but involves partially dismantling the motor so you can look through the exhaust port.
Posted on May 01, 2015
boscia
  • 163 Answers
SOURCE: Husqvarna leaf blower, replace starter cord Model 132 HBV
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Posted on Nov 30, 2008
  • 63 Answers
SOURCE: My leaf blower will not start, It keeps flooding
To start: turn the choke off, hold the throttle wide open and crank. You have a carb problem but this should get you going. John
Please rate if this helps-
Posted on Mar 20, 2009
slohry
  • 87 Answers
SOURCE: Husqvarna 130BT leaf blower - locked-up
If you stored it with fuel in it, the piston and cylinder may be stuck together. The old fuel turns to a gummy varnish. spray some WD-40 in to the cylinder through the spark plug hole and rock the flywheel back and forth to break it loose. Then flush the fuel system and carburetor. If that isn't the problem, remove the muffler and inspect the piston, rings, and cylinder for vertical scoring, if scoring is present a top end rebuild may be necessary.
Posted on Apr 13, 2009
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
vincob
  • 718 Answers
SOURCE: when we started using toro
You must use at least a 12 guage extention cord . Your current cord mostlikely can not handle those amount of amps for long duration of time.
Posted on Nov 07, 2010
130BT Blower can't pull start cord.
Can be a couple issues. The obvious is seized. The other is a broken jammed connecting rod. I would put some oil down the plug hole and let it sit overnight. Then after a day or so...try again with the wratchet. In both directions, forward then backward just to try and free it.
Nov 22, 2015 | Husqvarna 130bt 130 Bt Gas Powered...
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
My echo leaf blower will not start. How do I check to see if it is getting spark
Pull the plug out, connect it to the wire and lay the plug against the metal engine. Pull the starter cord and watch for spark at the plug.
May 15, 2014 | Echo Pb - 413t Backpack Blower
Snowblower won t start. pull cord too tight
How long has it setup? Could be varnished up, maybe broken ring, damaged needle bearings. Remove muffler an try to spray some cleaner or fuel in port to free it.
Mar 13, 2014 | Garden
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
I serviced the carburetor and i cannot get the pull the start cord
Make sure you have assembled the starter correctly, assemble loosley pull the starter handle until you hear the pulley fully engage into the starter pawls on the flywheel and the cover sits down easily, now fully tighten the screws.
Feb 10, 2013 | Solo 450 Mist Blower
Starter pull cord broke off
You can buy a new pull cord or start a any lawn an garden shop
Nov 09, 2009 | Craftsman 4 Cycle Blower/Vac
Echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Apr 06, 2009 | Echo Garden
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
