Question about Milwaukee 2610-20 18V Cordless M18 High Performace Drill/Driver
Batteries are fully charged. When I pull the trigger the led flashes on and off rapidly and that's it. Where should I look for the problem.
No drill action when trigger pulled. flashlight led just flashes rapidly and a small ticking noise is heard. Batteries fully charged and both had same problem.
2 Suggested Answers
SOURCE: Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
Posted on Dec 15, 2009
Milwaukee M18 fuel porta bandsaw will not run. I pull the trigger and get 8 flashes from the led light and thats all. I have tried a very different batteries and the same deal.
drill battery for MILWAUKEE M18 is 100% compatible and will meet or exceeds original specification. This M18 replacement battery made by Amstron has been tested for safety and designed for high performance. Replacement for MILWAUKEE M18 Cordless Drill Battery
Jun 27, 2017 | Milwaukee Drills
Drill suddenly loses power even though battery is fully charged,battery light flashes red
The battery cuold have a short in it and once you pull the trigger the battery drains or your charger is not working
Apr 17, 2015 | Panasonic Ey7546x 14.4v Li-ion Impact...
Makita Lxdt04: no response when trigger is pulled battery is fully charged
check carbon brush or the wirings to the motor of your hanf drill and check voltage of your battery if it can sustain the amount voltage needed by the motor of your hand drill. if the voltage is getting low then replace your battery with a new one
Aug 11, 2014 | Drills
Trigger Switch
I don't thinkk you got the motor aligned in the housing right. It sounds like it's in a bind causing the battery to over amp which shuts it down. The litium batteries have curcuits that detect overloads so you don't damage the battery. There are alignment guides in the housing and on the motor to help get it right.
Jan 05, 2013 | Makita Btd141 Lxt 18v Lithium Impact...
I have a Bosch 36v LI cordless drill the batteries are fully charged. However, when I pull the trigger, it starts briefly and then shuts down almost acting as though It's batteries are dead. I have...
One possibility is that the trigger on your drill has a short in it. When you replaced the brushes did you clean off your commutator? I am assuming that you did. You only need to clean the brush dust off of it and ensure the copper contacts are clean. Your issue is definitely with your drill. I am not sure about Bosch but with some drills you can take apart the trigger and check for contamination. Hope this helps.
Oct 23, 2017 | Bosch Drills
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Not spinning
Had the same problem figured out it was a wiring problem with the trigger, works good now.
Jan 15, 2009 | Dewalt DC900KL Heavy - Duty 36 - Volt...
Milwaukee 2610-20 18V Cordless M18 High Performace Drill/Driver  Logo
88 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
