Question about John Deere Garden
Replace an Pinion Gear on John Deere JE75 Moer
  • 218 Answers
SOURCE: blade position for 155c john deere
Hi..my name is Keith...to answer your question..there is no certain position to put the blades and there is enough clearance that they wont hit...but there is a proper torque on the nut when reinstalling the blade..and its usually like 100 foot pounds..i hope this has helped
Posted on Jun 30, 2009
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
spiegela
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
  • 100 Answers
SOURCE: Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
Can someone guide me through troubleshooting this ie which safety switches to check etc.
try a new spark plug. they breakdown over time. if still no spark unplug the wire under the coil. if it does not have spark now replace the coil. if it does have spark you have a bad switch somewhere.
Oct 30, 2016 | John Deere Garden
How to remove the steering shaft on a John Deere 125 Automatic riding mower?
should be enough room to get it ontry rolling it past the steering shaft
Aug 25, 2014 | John Deere Garden
Rebuild steering on john deere L120
Hi there, I am not familliar with the L120 specifically, and suggest that you go to: "John Deere Lawn Mower Manuals" online and select your model from there. In my experience with this type of unit there are two ways that the pressed gear on the end of the shaft is fitted.. Real engineers make a ferrule, usually about twice the diameter of the steering shaft, and have either a tapered end with a threadded end for a nut which often has a split pin thru the thread like a trailer wheel bearing, and a key in the shaft and taper. Machines made with a lesser labour input often have a fixed pinion which means replacing both the shaft and the pinion. If it is the tapered end with a nut, they are often very tight and cannot be removed while mounted in the machine. They may require a sharp heat and severe blow with a good hammer. I do not recommend that you do this if you are not competent as the blow to the nut can do much damage if not hit square with a cushion of copper between the hammer and nut. The fact that you do not know how to do this job probably means that it is cost effective to employ a shop which does this type of work.
Aug 19, 2014 | John Deere L100 Series
Replacing Drive Belt on John Deere La175
if the manual says it will slide off then it will but if it doesn't then it is probably rusted on or corroded on. It may be necessary to use a puller or press to achieve the desired result. I suggest you talk to a dealer mechanic to clarify that there is not a shear pin you have to remove first.
Jun 11, 2013 | John Deere Garden
My L130 will not turn right.
you will need to change the steering gear , and the steering pinion and its not a bad idea to change the gear pivots (2) and also the bottom steering wheel shaft bushing. they sell a complete kit on ebay that has it all in one nice n tidy kit.> http://www.ebay.com/itm/JOHN-DEERE-STEERING-GEAR-REPAIR-KIT-102-135-LA120-LA155-/261112192757?pt=LH_DefaultDomain_0&hash=item3ccb7fdef5
dont let the high price full you, just the pinion $40 and the steering gear $32 is $72 and you get both and the $10 bushings x2 plus for the same price!!
Apr 24, 2012 | John Deere 22HP VTwin 48" Riding Mower
Timing gear replacement for john deere js40
it fit between the crankshaft and flywheel
Apr 07, 2012 | John Deere Garden
My John Deer 1020 turns fine to the left but when turning to the right the power sterring does not work. It seems to me an intermittant problems. Occasionally the sterring is fine but most of the time it...
open hood to get to top steering gear check for lube and check adjuster worm gear known to crack or break a gear tooth than check thru view plate opposite of the steering cylinder which is connected to the rack&pinion make sure timing marks line up may have skipped a tooth or the thrust pad(shims) have shifted
Oct 30, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
37 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
