Windows 7 - adjust monitor screen??? using a 15" monitor and now have black space around picture.
    Problem Solver:
  • 5 Answers
Control Panel/Appearance and Personalization/Display/Adjust resolution. Try higher resolutions on the list.
If that doesn't do it I would go to Device Manager, and update driver for display adapter. May need to go to the manufacturers website
and Support Tab for drivers.
Posted on May 03, 2015
  • 624 Answers
SOURCE: How to use buttons on front of Monitor for vertical Horizontal settings
Oldie, The first thing to do is set the monitor resolution, color depth and monitor refresh rate to what you want then adjust the monitor accordingly. Adjust resolution, color depth and refresh rate for Windows 2000/XP: -Right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) experiment with the resolutions and see what you like. -The color quality box should be set to the highest (most colors) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -Typically you would want to set it at 70 Hertz or better. The higher the setting the less flicker you will notice, however, there is always a trade off. I would start with 70 Hertz and gradually move up; at some point your monitor will reach a setting it can?t support. If the screen blanks out Windows will reset back to the previous settings as long as you don?t hit any keys. -click the OK button twice. More to follow?.
Posted on Mar 14, 2007
SOURCE: only 3/4 of the screen is being shown...
Ok so I have actually had this happen to me before. My best guess would be that it is a problem with the video card. There may be some video drivers that you need to download. The other explenation might be that the video card over heated.
When it happened to me the whole screen went blank all together after the login screen so at that point it wouldn't load Windows. If you're still covered under the warranty then you're good and set and you could get it within a couple of weeks if you send it to a tech service (preferably the company that built it)
Hope this helped
Posted on Nov 05, 2007
  • 4 Answers
SOURCE: Black Screen-No picture
Normally when an LCD monitor goes black, it is because the inverter goes out (which essentially is the backlighting).  To verify this problem, hold a flashlight up to the monitor while it is turned on and see if you can "see" the picture.  If this is the case, it could be repaired, but realistically, the cost to replace it might be cheaper (and you would probably end up with a larger monitor to boot).
Posted on Jan 01, 2008
ariyoso
  • 145 Answers
SOURCE: No display
I think the problem is on the resolution, or you can change the video card, but if its happen to another computer..then u have to contact the ACER support center
Posted on May 27, 2009
parrotheadpc
  • 2600 Answers
SOURCE: I just upgraded to Windows 7 and can't adjust the
Changing the resolution on the screen is the job of the graphics card on the computer. Either run windows update or visit the card manufacturer support site and search for an appropriate driver or software package. ATI and Nvidia both have "control panel" add-ins that will come up when you right click on the display. scroll down to the control panel and all your settings will be there.
Posted on Nov 25, 2009
I accidentally hit the auto-adjustment button on my monitor. Now, the an inch of of my screen from left to right is black. Not even my mouse can go into the black space.
Did you try hitting the Auto adjust again to possibly shut it off. Quite often the buttons work as off and on buttons such as the Caps Lock. you hit it and it's on. You hit it again. It's off. If you hit the Auto adjust it might shut off and re-adjust your screen to the original setting you had. ....don't forget that you made other adjustments to compensate for the mal adjustment that will need to be fixxed. good luck.
Dec 22, 2014 | HP W2072a 20in. LED-Backlit LCD Monitor,...
LG M197WDP, used as a monitor with a Windows 7 computer. Intermittently the monitor goes black for 15 to 20 seconds then the picture returns. I have checked drivers etc all up to date. Anyone able to
Could be a hardware issue, If the screen has a power light, does it change coulor (often green to orange) when the problem happens. If so its the screen inst getting any signal. It could be a connector or cable.
Nov 01, 2014 | Computers & Internet
MY HANNSPREE MONITOR HF237 SUDDENLY WILL NOT STAY CONNECTED TO MY LAPTOP I JUST HAVE A BLACK BLANK SCREEN. I AM USING WINDOWS 7 ULTIMATE
On laptops there is a key sequence that you can switch between monitor states, it's possible you have it in Laptop screen only. Look for the "Fn" key and then hit the Monitor button (it has a picture of a monitor) usually this is somewhere around F5 or F8.
May 19, 2011 | Office Equipment & Supplies
I have a NEC AccuSync LCD5V monitor and the picture on the screen will not extend over the whole screen....the right side has the picture re starting by about an inch
Windows 7 & Vista:
Right Click on your desktop and go to Personalization. Click on Desktop Background at the Bottom of the screen. On the Picture Position drop down menu, click Stretch and save changes.
Windows XP:
Right Click on the Desktop and click Properties. Go to the Desktop Tab. Select stretch from the drop down menu. Apply.
Please Rate my answer. Thank you.
Apr 19, 2011 | NEC AccuSync LCD5V-bk (Black) 15 in. Flat...
I purchased a Dell ST2320L monitor. When I am in Windows, there are black bars on the top and bottom, as well as the sides. When I am gaming, however it is full screen. How do I adjust the monitor in...
thats really odd that windows 7 doesnt give you full screen but the game does? change your resolution settings around to see if that helps altho i doubt it. check menu settings on your monitor and see if you can change its aspect ratio
Mar 23, 2011 | Dell ST2320L Monitor
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
H243h screen not using its full space on the
Control panel-Appearance and themes-Display-Settings-Advanced. Then adjust to suit
Apr 09, 2010 | Acer 22" X223w LCD Monitor
How do i adjust the screen resolution on my monitor?
right click on desktop then go to the properties > select settings> then change your screen resolution whatever u want.
Dec 11, 2009 | Cars & Trucks
My screen is x X y inches. The windows page doesnt fit into it. There is one inch of black space on the monitor on the left and one inch of my windows screen is lost on the right!!!!!!!
With the on-screen controls, select Auto-Adjust. This should set suitable defaults based on the incoming signal. If you are using the VGA connector and the position still needs to be adjusted, use the on-screen controls to shift the displayed image to the proper location (under Display Settings -> Horizontal Position).
Apr 17, 2009 | Dell UltraSharp 1908WFP 19inch Black...
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
