Question about Refrigerators
I want to find the year of fabrication of my refrigerator. Thanks
  • Refrigerators Master
  • 932 Answers
Krystel,
Try the following link and scroll to the bottom and fill in your information. You will need make, full model #, and the serial #. Hope this helps!
Appliance411 Service How old is my appliance Age finder date of...
Posted on May 02, 2015
  • 473 Answers
Not all refrigerators list the actual date on the serial plate. Most companies use a code or set of letters in the serial number that techs can read but the average person won't understand. For example on GE products the serial numbers always start with 2 letters and then 6 numbers. The first letters depicts the month and the second letter is the year code. However you need a special list to know which letter means which month and year.
  • 744 Answers
Hello;
There is a label on the inside wall of your fresh food section with this information.
Where to buy acylic seif and vegetable bucket
if fridge is less than 5 yrs old you. contact the fridge manufacturer
if more than 5 years old
a refrigerator repair shop may have a used one
see if someone is selling a used fridge the same as yours
ebay
or its DIY repair on your broken one with fiberglass repair kit
of diy fabricate with sheet of perspex
Aug 18, 2016 | Refrigerators
The fabric softener compartment in is full of water. I need to empty this manually prior to each wash . Many, many thanks. Judy
The fabric softener dispenser has to be purged between wash cycles to prevent residue from clogging it. What you are observing is normal operation.
Jun 25, 2016 | Washing Machines
Hi, I bought my Frigidaire refridgerator in June 2002. Within a year the compressor had to be changed. In November 2009 the compressor died again. A new one was put in. Last week it quit again. The...
Who is performing this service ? The line he is referring to is the liquid (capillary tube) suction line which is welded together for proper heat exchange. If that is the case then this should be addressed by the manufacturer. Was the system properly evacuated and a new drier installed ?
Was the condenser clean ? The newer refrigerants along with overheated systems cause any moisture in the system to release salt which mixes with compressor oil. This sludge clogs up the capillary tube stopping refrigerant flow.
Jul 13, 2011 | Frigidaire Refrigerators
The fabric trim on the front door of my 1994 Toyota Camry is coming away from the door. How do I refasten it to the door. It does not appear to be glued. Thanks
My experience with fabric in cars is it glued onto something if it not sewed. They make a spray on glue made specifically for auto fabric repairs. You spray it behind the fabric, press down the fabric, hold it for a few seconds (as directed) leave it alone overnight and that's it! Good luck!
Mar 15, 2010 | 1994 Toyota Camry
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
Need help fast w/ older Kenmore...
hi thanks for the question you mean liquid fabric softener in agitator if this the case if the fabric softener stayed in agitator this means it did not spin check the spin cycle to see if it spins thanks the appliance doc
Aug 17, 2008 | Kenmore 22422 Top Load Washer
Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Mar 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Fabric softener will not dispense
water remaining in the dispenser is normal doesn't mean its not dispensing consult your owners manuel
Jan 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
