Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
I need a description for how to open and clean the grinder. I keep getting fill beans message and it has beans.
    New Friend:
  • 3 Answers
I have not done it, but I believe you simply remove the two screws you can seen when you look into the coffee bin.
I used to get "fill beans" messages when there were beans in the hopper. Eventually I determined this was due to my choice of beans: oily (ie. shiny) beans seem to clog up frequently, "dry" beans (beams without a sheen) rarely clog up.
Since the beans are gravity fed, oily ones tend to stick to one another
Posted on May 01, 2015
    Master:
  • 412 Answers
Some models, such as C60 and C65, have a plastic disc about the size of a silver dollar as a guard above the grinder, with very little clearance for the beans to feed below the guard. Oily beans can stick together and hang up on the guard. I noticed when the Fill Beans problem happened, that the grinder didn't sound like there was anything in it, just a whirring sound of the motor.
My field modification to solve this problem was to remove the guard (1 screw), add a 1/4" spacer (made from a 10-24 nut) beneath the guard, giving more clearance. Beans fed great, and the screw was just long enough to re-mount the guard with the spacer below it.
To do this:
1. Unplug the machine.
2. Open the top of the machine. On C60 and C65, there are two OVAL head screws on the back. If you don't have an oval head driver, you can grab them with small vice grips and work them loose. At the top front under the side lids there are two torx screws - much easier to find a driver. Remove the lid, being careful with the wiring to the power switch. The lid can be moved aside with the wiring still connected, just enough to access the guard.
3. Remove enough beans to expose the guard, and remove the torx head screw and guard
4. Put your spacer in place (anything metal or plastic about 1/4" thick with a hole in it will do), and replace the screw, being careful not to over-tighten and strip the threads. You may need to find a similar self-tapping screw 1/4" longer.
5. Replace the top and the 4 screws that secure it. Plug it in and try it.
This turned out to be a bulletproof fix for my machine. I thought about discarding the guard entirely, but seemed like a better idea to leave it in place. You can watch the beans happily feeding into the grinder, and no more Fill Beans light until you actually run out of beans!
Posted on Mar 13, 2017
HOW DO I CHANGE THE GRINDING MECHANISM ON MY SPIDEM TREVI EXCLUSSIVE ESPRESSO MACHINE. I HEAR THE MACHINE GRINDING BUT IT'S REALLY NOT DOING ANYTHING. ANY SUGGESTIONS
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Feb 10, 2015 | Spidem Coffee Makers & Espresso Machines
I keep getting "Fill Coffee Bin" when the bin is
Sounds like the grinder is blocked. Set the grinder to the coarsest setting (largest number) and try a few more times. If still no luck then vacuum out all the beans, run the grinder again a couple of times and then add a small amount of fresh beans (not from a fridge or freezer as these will be moist and can cause problems) and try making coffee again. If after a few tries it still doesn't work then you will either have to remove the top grinder burr and clean both burrs (not recommended unless you are bit of a handy person) or you could try vacuuming out the beans again and letting the grinder dry out for a while (although unlikely, it could be wet from water spillage). Good luck hope this helps.
Dec 14, 2010 | DeLonghi EAM3400 Espresso Machine
Cuisinart coffee grinder keeps clogging
Unplug first. Unscrew the top. You need a long thin screw driver Phillips head is the best. Pock around the exit and entrance where the coffee beans are ground. Remember, the better the coffee and you will get more clumping of the beans. I works great. It is pain. The Chicago Clout man exits.
Feb 06, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
The machine says FILL BEANS but beans are in it...yes, we did run out of beans but now it won't recognize beans. we cleaned it out, grinded , etc...but it still says fill beans. We also rinsed many times,...
Hi
Oily beans (shiny) can some times stick together after grinding with a fine setting. Try opening the grinder setting to the very coarsest setting and see if it will clear the passage. If you have pushed the brew button an lot of times you may have packed the grounds in the passage which will have to cleaned manually.
Once you have the grinder working again, open it to the coarsest setting to clean the burrs. 1 time is enough. To turn the grind setting back down to your setting make sure that the grinder is running at that time. You can open to a coarse setting any time but it has to be running to finer.
Oct 25, 2009 | Jura Capresso Impressa S9 Coffee...
I bought new green coffee beans recently, roasted it myself and wanted to use it in the machine but the grinder gets stuck and won't turn. The new beans are harder and smaller than the type I used to have....
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Oct 21, 2009 | Gaggia Paros Espresso Machine
Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Aug 14, 2009 | Jura Capresso Impressa E9 Espresso Machine...
It is says fill the beans even if the are full, snd dont make a coffee
Your grinder is probably clogged with fine powder. Set the grinder adjustment to a coarser grist, and see if this pushes out packed coffee from the grinder. Open the lid for preground coffee and clean out the outlet from the grinder.
It is the tamper in the brew unit that feels if there`s enough coffee before brewing. If this gets to far down during tamping, it will send a message to the mainboard that there`s not enough coffee, and the message Fill Beans will appear.
Aug 02, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
Gaggia Titaminu
check to make sure the blades are secured to the motor shaft. some have a set screw, some are positioned over a pin in the motor shaft.
Sep 10, 2007 | Gaggia Titanium Espresso Machine
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
972 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
