Question about Epson PowerLite 3LCD Projector
What does it means when a red temp light turns on
Alight i have a 1999 mercury cougar and a light popped on the other day and i have no clue what it means. the light is on the headliner bundle of lights. please help. thrashbash_sk8r@yahoo.com
If the light on your cougar has a wrench on it then this is your "Interval Maintenance light", it comes on when your car is due for a scheduled maintenance as prescribed in your owners manual (oil changes, transmission fluid, etc). Another light located on the upper cluster is the "Outside Temp Freeze Warning Light", this light looks like a yellow or red snow flake, if this light is yellow it means it's nearly freezing outside (so watch for slippery roads), and if this light turns red it means that it's 32 degrees or lower
Dec 14, 2009 | 1999 Mercury Cougar
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
What does the blinking red light mean? The
it means that you have probably blown a capacitor or 2 in the back of the set. Take the back panel off and look for the round capacitors that have a cross. If any of them are bulging, they are blown. You can order new ones at most electronic parts stores, just get all the readings off it, temp. range and farad readings. They cost less than a buck each. They need to be soldered onto the board.
Nov 19, 2009 | Philips Televison & Video
Temp light
well blue is OK when thermostat opens it should go off this means the car is at operating temp as long you do not have orange or red temp light should be OK hope this helps
Sep 18, 2009 | 2000 Volkswagen Beetle
Red warning light is on and f1 flashes were the temp shows 04gsxr
blinking red light means critical error check your oil if you have oil in the motor check the sensor on the oil pan! good luck! had the same problem wire was bear making contact at bottom near oil pan good luck!
Aug 29, 2009 | 2004 Suzuki GSX-R 600
The red lights are blinking under lamp and temp.
did you try setting the lamp over the red light on the tv?
Jul 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
The green light is on ,the red light is on over the temp, and red
your backlight might be burned out same thing happen to my grandfathers and it turned out to be the backlight was burned out just call company if its a sony number is 1800-345-7669 sorry i dont know other companies
Jan 08, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Why is the ''snowflake light'' showing up red in my car?
I have a '99 Mercury Cougar & I've been read somewhere that the snowflakes have to do with the outside temp. & traction. I think it's warning you that it may be slippery or icy. I've noticed that when it's +3 to about -2 or -3, the yellow snowflake shows up. Any anything colder than -3 shows the red snowflake. The other lights: the wrench comes up in yellow. That one has always turned on after a certain amount of km's & it's advising you that your car needs a check-up (that's when I know I should look into getting an oil change). You can turn this light off by holding down the two buttons above & below the 'clock' button. Hold them down together for at least 5 seconds & that wrench light should go off. Otherwise, there is a light for checking your breaks (upside down exclamation mark), low windshield fluid. I can't think of any other ones but I hope this helps.
Nov 18, 2008 | 1999 Mercury Cougar
RED LIGHT ON FRONT
yes you need to turn the contoller fropm the bake position to the off position most likely the temp is turned down so the oven wont heat up
Jul 09, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Need answers
The fan may have went bad. If it's out of warranty you may open it up and try and blow some dust out of the fan to see it that may do the trick if not it may need to be replaced. Westexaudioelectronics.com
Oct 04, 2007 | Televison & Video
Epson PowerLite 3LCD Projector Logo
63 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
