Question about Cartier Carter Must De Vermeil Watch, 7/10 Condition
Need to know brand and number of a proper replacement battery.
Got mine second hand and didn`t have the battery in place. Thanks
  • Cartier Master
  • 2,454 Answers
A jeweller would help you do that mine did.
Posted on Oct 13, 2016
Battery on m Invict Pro Diver watch replaced , now the second hand stays swinging back and forth in the same place
Do the minute and hour hands keep proper time? I've seen your problem before when the hand has come loose from the center post that turns it. You probably need someone who knows what they are doing to pull the crystal and reseat the second hand. Do this when the watch is off!
Sep 08, 2014 | Invicta Pro Diver 9309 Watch for Men
I replaced the battery in a garmin nuvi 1300 but does not work?
check if it is installed properly and in place and same brand #. And before putting the back cover check if the hands are moving. If not, battery may be defective.
Feb 26, 2014 | Garmin Forerunner 50
I replaced the battery in my watch. About a week later, it started getting slow. I watched it and noticed that it would tick for 2 seconds then stop for a second, tick for 2 seconds then stop for a second,...
It sounds like one of the hands is pausing as it brushes against something. It sounds like a treasured watch. I would take it to a professional watch repair shop. Mine was losing a minute or two per hour from the hand being slightly bent. Good luck!
Sep 03, 2017 | Timex Indiglo Analog Watch
My watch ar2434 is not functioning properly. the seconds hand moves for some time and then stops. i changed the battery but the problem still persists. what could be the problem?
mcdevito75 here, The quatrz movement could need a little quartz oil or the quartz movement could be going bad, but foirst check make sure you have the correct battery and that it didn:"t work loose Return to whoever changed the battery to have it checked.
Jul 21, 2010 | Watches
I have a Junghans Mega Atomic mantel clock (grey dial with green hands) that is about 15 years old. It worked without a glitch but recently the hand of the seconds detached itself and fell. I am looking...
First, reset the clock to 0:00 hours. The instant the clicking stops, pop out the battery. The second hand stem should be at 0:00 hours. The front cover can only be removed from the bottom. Put both thumbs at the bottom of the font cover and push inward, but not too forcefully (Junghans stopped selling replacement covers shortly after dropping the product line and they are nearly impossible to find). The center should lift up enough to slide a thin credit/promotion/gift card under the center tab on the bottom. Then work the card up either slide to disengage the other four tabs. The five tabs are located at the bottom center, one each on both straight sides alligned with the top of the digital display, one at 7.5 minutes, and the last one at 52.5 minutes. That is easy part. Now comes the hard one You then need to glue the second hand back onto its stem. Superglue (cyanoacrylate based) works best. The second hand must be attached perfectly level or it could scrape the cover, the clock face, and the other hands as it rotates on a tilt. Practice a few times before applying the glue. You will notice that the socket on the second hand fits the stem very loosely. Once you are ready to glue, apply one drop of superglue on the second hand socket and mount it on the centermost stem and hold it perfectly still and in proper alignment and steady for a minute or so for the glue to set. Once the glue dries, put the battery in and let it run long enough to determine if the second hand is in correct alignment. Remove the battery again. Make certain the clock face is completely free of dust and dirt before reattachment of the cover. Insert the cover from the top down snapping the five tabs into place. It may be necessary to reverse the removal process. Then you can reinsert the battery. The process worked for me when mine was accidentally knocked onto the carpet and the second hand was detached from the force of the impact. In fact, I can no longer tell which one I performed the repair on.
Apr 08, 2010 | Watches
Stuck second hand
You need a new battery, as there is not enough power to move both gears. You can send it back to Wenger and get battery replaced or just pop into your nearest watch repair shop and get it replaced. It will cost you $5.oo and will be done in 10 minutes time instead of months of waiting it back from Wenger. Rate me, plz.
Feb 26, 2010 | Swiss Army Wenger Commando 70728 Wrist...
My Tissot Watches second hand jumps 3-4 seconds bursts.Why?
The second hand jumping three or four seconds .I have had this same problem and found out that its i sign of wanting a new battery.Mine is now perfect
Jan 24, 2010 | Watches
How to replace the battery in a kenneth cole watch kc3346
I have not figured out how to open the casing lid to replace the battery, but the number for the battery you need should be engraved on the lid. Double check your own lid, but mine says that the battery is an SR621SW. I'm sure there are different brands that would match this number.
Jul 05, 2009 | Kenneth Cole Reaction Blue Marine Dial...
Problems with Tag Heuer 2000 Classic WK1120.BB0314
Explanation is simple: your watch has jammed geartrain or some dirt particles stuck into geartrain. This is why the seconds hand was moving backwards and forwards.
Nothing to do with EOL (End Of Life) feature wich is built into watch microelectronics and signals that this is the time to replace battery by advancing seconds hand two or four seconds at once.
To open the watch you need a proper watch caseback opening tool, but I can't see any reason for doing that as you will not be able to fix the geartrain problem without proper knowledge and skills.
If the warranty of the watch is expired, you don't need a TAG specialist as you will be charged for job anyway. So, find your nearest watchmaker shop and ask for repair.
Do not forget to rate, please.
Feb 14, 2009 | Tag Heuer WK1120.BB0314 Wristwatch
Cartier Carter Must De Vermeil Watch, 7/10 Condition Logo
29 people viewed this question
Top Cartier Watches Experts
k24674
john h
Are you a Cartier Watch Expert? Answer questions, earn points and help others
