Question about Acer Aspire Computers & Internet
I want to open cd rom dont have any button - Aspire Acer Computers & Internet
  • Acer Master
  • 3,320 Answers
Open Windows Explorer and click on the CD rom drive. It will open. Or right click on it and a menu will open. Click on Eject
Posted on May 01, 2015
1st sorry for my bad english ... but my cd rom dont want to open . when i press the button the green light turns one and i hear a sound, but the cd rom dont open , can u solve this please? ... thnx
This happens when the drive motor inside dies.
You can take a small paperclip and insert it into the tiny hole you find in the face of the drive to manually open the tray. Use this method to remove any disk stuck inside of the drive currently. go to www.newegg.com for a cheap replacement drive.
Aug 24, 2011 | Samsung (SC-152) Internal 52x CD-ROM Drive
I dont know how to open the burner on my new emachine e732z. ive tried pressing the button and notrhing or maybe it isnt a button
On your front panel of your CD rom you will see a small hole insert a small needle that can press the lock of the cd rom eject and it will open. You can use a paper clip.
Jul 29, 2011 | E-Machines emachines (emachinees) CD-ROM...
The cd door on my dell computer model #: IN1910N keeps poping open. everytime i turn on computer it opens. then i close it and wont stop poping open
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
dont forget to vote
Feb 25, 2011 | Dell Computers & Internet
Sony DVD ROM will not open, light comes on and tries to open but will not. Other DVD works fine. What with the Sony DVD?
try to find a tiny hole on the drive( near LED or eject button) and insert a niddle or some kind of hard pin which can go inside of it push little bit hard (drive will open) , dont keep your drive empty if not in use put any useless DVD ROM in it so that it will get open when you want to use
Apr 24, 2010 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
I cant get my cd rom to open.. and I even hit the reset buttom and it wont open at all.. I dont want to force it..what should I do
ok take a sharp niddle... now you wil find very small hole near the open button on drrive
Dont worry insert niddle in that hole
that wil work
and your CD ROM wil get open
Mar 06, 2010 | Dell 48X Half-Height Serial ATA Internal...
The door on my cd rom cant not open when i eject, i dont hear the motor but the light shine just at start up
Look on the front of your cd-rom, there should be a small hole somewhere just under the tray portion. Turn off your machine (to avoid possible short-circuit issues) and use a thin piece of wire (ie: a straightened paper clip) and insert it into this hole. Push it gently, you will be able to feel the unit unlocking itself and the tray will open slightly. Now you can use your fingers to pull the tray open. Be gentle when opening, you don't want to mess up the gearing.
Oct 07, 2009 | Computers & Internet
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
Cd rom not detected
Sounds like the CD drive has failed. First try removing the drive from the machine, clean the connectors and put it back, make sure it seated firmly and properly. If it still doesn't work, then do a system restore. At this point, if it's still not working, then it has failed and will need replaced.
Aug 13, 2008 | Computers & Internet
Help
Your CD-ROM may still be functional. The tray may just be stuck, instead of broken. First let's remove the CD.
Get a large paperclip and bend the end out straight. Look for a tiny hole underneath the CDS tray. Push the end of the paperclip into it, and it should open the CD tray a little. Then pull it out the rest of the way and get your CD out. Then try pushing the eject button on the CD-ROM to get the tray to go back in. It may take several trys. If that does not work push the tray in, slowly. Then try the eject button again. I hope that works.
If it does not you can continue to use the CD of course (lots of CD-ROMs have paperclips hanging out of them. And I've seen the problem go away, occasionally, after continued opening and pushing back the tray.
Mar 10, 2008 | Acer Aspire L100 PC Desktop
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
