Question about Schwinn Cycling
How do i remove the rear wheel on a 3 speed schwinn occ chopper
4 Suggested Answers
  • 1788 Answers
SOURCE: old schwinn 10 speed rear
Release rear brake, either will have a lever on brake assembly or remove a brake shoe, shift to the smallest gear in rear, then loosen with a #15 metric box wrench, then push the wheel out. All bikes are metric, not just Schwinn. Then reverse to reinstall.
Posted on Sep 13, 2010
  • 20 Answers
SOURCE: removal of rear wheel with internal geared 3-speed and coaster brake hub
Find the joiner link on the chain, remove the retainer clip followed by the link. Remove the chain. Remove the bolt holding the brake arm to the frame. Loosen the axle bolts on the wheel enough to be able to slide the rear wheel out of its slots on the frame.
Posted on Feb 24, 2012
  • 109 Answers
SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment...
Wow Lady Hawk, it's hard to tell from what you've said. I've seen chains jump off their gear and get jammed, preventing the bike from moving. If the chain is off, you need to unjam it, then properly install it on the back gear. Next place the chain on one or two top teeth /cogs of the front gear. Next you turn the crank forward and this will move the chain forward onto the front gear.
Posted on Jul 22, 2013
How do I change the inner tube on my rear tire
This is no easy task!
You will need to remove the rear wheel to access the wheel, tire, and inner tube
Unless you have a single speed rear axle, you will be needing to disconnect the multi-speed gearing, which you may not really enjoy.
God bless your efforts.
Apr 19, 2016 | Schwinn 24in Riverside Girls Cruiser Bike...
How can i find the manual book on a schwinn OCC stingray pedal chopper bike model S2914WMA
More than likely you won't be able to find a manual, but the good news is that most bikes are pretty generic and you can go to your local library and find many bicycle repair manuals that will give you the information you need on how to do any repair for that bicycle. Also YouTube is a good resource.
Oct 17, 2015 | Schwinn Cycling
Removal of rear wheel with internal geared 3-speed and coaster brake hub
Feb 24, 2012 | Cycling
Chain slips like it was trying to come off
If this is a seven speed Schwinn bicycle, you may be able to adjust the rear wheel (loosen the mounting nuts and slide the wheel rearward) or you may have a "stretched" chain and will need to remove a link (not an easy task without a chain breaker), hope this answers your question.
Dec 14, 2011 | Garden
I have an old schwinn varsity. I went to change the rear tire, and turned out the rear axle bolt is stripped and I can't put wheel back on. Where can I find a replacement axle bolt?
you need a new axle kit, and a cog removal tool. They used to be a Huret dearailleur if I remember right. I know a varsity never had Shimano. I think you may be better off buying a new rear wheel (it is usually less money than having to rebuild the axle) and let the bike shop do the change over, it is well worth it. You wont have to deal with the brakes,check the cones etc. Why did you have the Meridian adult trike on, and you have an old 10 speed Varsity? Kind of confusing.
Sep 18, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Old schwinn 10 speed rear wheel removal how
Sep 09, 2010 | Cycling
Schwinn Stingray Chopper master link on chain
look for adifferent looking link more oval than the rest it is also possible that there is no master link that the chain was joined with a chain tool especailly if is a multi speed bike with a derailleur
Nov 14, 2009 | Schwinn Stingray Chopper Youth Bicycle...
How do you use the 21 speeds on the Schwinn ladies coaster bike?
there are 7 cogs on the rear wheel hub; three on the crank hub:
7x3=21 gear change possibilities
large gears move the wheel faster and farther around but, with more effort
small gears move the wheel less distance but, with less effort
i.e. 10 teeth divided by 30 teeth= 3:1 per 360 degree rotation of the bicycle wheel
Sep 07, 2009 | Schwinn Cycling
Replacing occ stingray front end
As long as the neck of the fork that goes into the frame is the same length and width (or circumferance) it should fit.
Feb 13, 2009 | Cycling
Cycling Logo
81 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
