Winter halter glass washing machine wash tank water drain slowly slowly what is the problem
  • Washing Mach... Master
  • 3,368 Answers
It sounds like the drain may be partially clogged.
http://www.winterhalter.biz/fileadmin/en/korbsortiment/Glasklar_e_UK.pdf
Posted on May 01, 2015
    Genius:
  • 1,585 Answers
Pumpy pumpy blockage
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
Drain outlet maybe blocked drains too slowly
need to check ur drain hoses and the water pump for blockage or obstructions
Jun 19, 2015 | Washing Machines
Hobart dish machine low wash temp
make sure all the curtains are there ,also check for any baffles missing from mach. should be 2 1 on incoming side 1 on outgoing, also ck hood vents had problem before with vents wide open sucking heat right out of warewasher
Jan 09, 2010 | Dishwashers
How do I winterize bosch front loader washing machine
Turn off the water supply to the washer, and disconnect the inlet hoses, remove the drain outlet hose and lay it down to drain any water in the hose.
Remove filter, and drain water off inside.
That should do it.
Hope this helps.
Dec 10, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My washer leeks water from bottom even when its not running and just sitting there. Seems after a wash the water hasn't totally drained out and then slowly starts leeking, actually alot of water is on the...
Have you checked the clamp on the drain hose? It may need tightening. All washers keep a small reserve of water in the bottom of the basket tank. If your drain hose hook is too high from the top of the washer, that much more water will be held below.
Aug 13, 2009 | Westinghouse Washing Machines
Water will not drain from machine
one of three thing is happening,lid switch is bad,the motor coupler that turns the water pump has broken or the water pump itself is broke or clogged with somthing,you can check the lid switch buy lifting and closing the lid slowly to see if you hear the clicking sound,to remove cabinet remove the 2 head screws one on each side of head,flip up,use a screw driver two remove the 2 spring clips one on each side under head,unplug lid switch,tilt the cabinet toward you and pull it off,you now can check the water pump and motor coupler,let me know what you find-mike
Apr 08, 2009 | Kenmore Washing Machines
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Water backs up into washing machine after washing a load.
check your drain hose and drain pipe,if not that then i think your inlet water valve is not closing all the way,try it on cold only see what happens,then try on hot only see what happens,let me knoe what you find-mike
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a hobart dishmachine model# CRS-66AW after filling dishmachine water will not stay in the wash tank, sometimes half of the water drains out. we have replaced the o-rings on the drain plug recently....
Which tank is loosing water?
Number 1. Make sure all curtains inside are in place.Curtains help keep the water in the proper tank. For example, curtains are missing between prewash tank and wash tank, the wash tank water could be significantly splashing into prewash tank and out the p.w. tank overflow. Are you ruling out the drain because you replaced o-rings? Look at the floor drain as machine is running. Do you see a large flow of water going down drain? There is a drain heigth adjustment on the drain lift. Mabe the drain stopper is not dropping far enough.
Mike
Mar 07, 2008 | Dishwashers
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
