Question about Dryers
Our fan remote quite working, found out we needed fan transmitter the fan was stuck on low speed, new part installed and fan no work
    Genius:
  • 1,617 Answers
Make sure the frequencies (dip switches) are set the same in the receiver & transmitter. You can check the old transmitter for the code or check the dips in the receiver.
Posted on May 02, 2015
  • Dryers Master
  • 3,368 Answers
I do not think your diagnosis was correct in the beginning. If it wrere the remote it would have to be stuck which would cause the battery do die, then the fan would resume normal manual mode. On the new part either it was installed wrong, or a defective part. If you post for more information please add the fan manufacturer and model number.
Posted on May 01, 2015
    Genius:
  • 1,585 Answers
New part probly not inserted right check wires
Where are the numbers on the motor housing hunter Douglas fan to operate remote
I'm not totally sure what you're asking? Do you need the numbers on the fan because of a bad motor, and need information for it? Or, are you looking for information to operate the remote - which is usually found in the owner's manual - which I'm sure you know already. Or, is your remote not working - and you think there's information on the motor to help assist you? Or, are you not sure why your remote isn't working - and think it's the motor? Well, the remote has a transmitter up inside the canopy - next to the ceiling, where the fan is attached too. This is usually the reason why the remote doesn't work - unless you need new batteries. It's always good to put brand new batteries in a remote, because a lot of times - people take from a drawer, cabinet, another appliance, remote, etc...and this doesn't always solve the issue. Without going into the phenomenom of electrical theory, etc. - I'd just try new batteries, if you haven't done so already. Otherwise, you'll need a new transmitter. Now, the way to see if this is the problem - is to turn off the switch (or better yet, the electricity) that operates the fan - and remove the transmitter. Then, reattach the wires directly. You should have one Hot wire (usually colored, but not always the case) - and one Neutral wire (usually the white wire, but not always the case. After you connected the Hot wire to the colored wire of the fixture, and the neutral wire to the white wire of the fixture. Go back and turn your power source back on again. This should allow you to work the fan with the wall switch. If it comes on, then you know you need a new transmitter. Otherwise, there could be an electrical issue up in the ceiling, or somewhere. However, I don't believe you'll have to go that far. Try the new batteries first, then bypassing the transmitter next - and I believe you should have your answer by then. Good Luck, and I hope this will help you...Jim
Jun 16, 2014 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
Hunter fan 27185 has lost speed
Remote controlled ceiling fans can suffer a lapse of memory when there is a power outage. You eliminated the possibility of a dead battery in the remote by installing a new battery, but just to be sure remove the new battery and press all the buttons on the remote to eliminate the possibility of a stuck button then reinstall the battery. Next disconnect power to the fan at the breaker box, not a wall switch or by tugging on a chain. Turn the fan power on again. Using only the remote, check operation.
Apr 20, 2013 | Hunter Dryers
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
HUNTER FAN PART # 85095-1
Either need new transmitter or receiver or both. Call 1-888-830-1326 to order parts.
Jan 07, 2013 | Hunter (25417) Ceiling Fan
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Windworld III has mind of its own -- light comes on any time it likes fan changes speed
This sounds like one of the most common problems with Hampton Bay's remote-contolled fans...either the transmitter (remote control) or the receiver (mounted in the fan, typically inside the ceiling canopy) has gone haywire. A circuit has blown or something is short-circuited, and it has a mind of it's own. The only fix is to replace the receiver and transmitter, which are relatively cheap and sold as a pair at your local Home Depot and Lowes.
Hope that helps! If you ave any other questions, feel free to ask!
Jun 14, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
55 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
