Question about Stihl FS 85 Weed Eater
Now it runs 15 min. then stops. - Stihl FS 85 Weed Eater
    Genius:
  • 1,585 Answers
Sounds like fuel blockage
Posted on May 01, 2015
Er5 runs for approx 15 mins then stops
More info needed. What have you done, if anything? Is it in good condition, needs a service?
Apr 21, 2014 | 1998 kawasaki ER-5
My car Renault laguna 1999 model hatchback, stop after 5-10 min run.and start working after 10 to 15 min wait.i also note that the car exhausted more fuel then before
try this ?= renew the throttle fly by wire control inside the the car ,they go just like the way you describe ,car runs then just stops ,leave and it goes again ,trust me been their got the teashirt on this one ,some customer paid out over 2000 euros to a renault garage for the same fault and it was still the same till a little bird told me what to change ,with one from the scrappers it been ok ever since
Nov 19, 2013 | 2000 Renault Laguna Estate
My car laguna 2000 modeel stop after 5-10 min run.and start working after 10 to 15 min wait.
Behind your harmonic balancer there is a cranshaft position sensor. When its getting hot its loosing calibration. Have that checked out.
Nov 18, 2013 | 2000 Renault Laguna Estate
94 olds cutless supream 3.1 starts runs then stops running after 15 mins
Have you had the computer checked for trouble codes,that would be the first step.If you have then start testing separate componets,coil, ignition module,etc.
Jul 02, 2012 | 1994 Oldsmobile Cutlass Supreme
The fan stops running
check whether the power saver mode is on. put it off. or some timer must be on. stop the times. it wll be rectified
Jul 27, 2009 | Heating & Cooling
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Apr 25, 2009 | Garden
Stihl FS 85 Weed Eater Logo
77 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
