Question about Home Security
Lost manual want to change code for pilot super safe model no 1610
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
SOURCE: changing the combination
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You must have the factory combination in order to change the combination that was added to the safe and the factory combination can not be erased if that is the combination you are trying to erase.
All you have to do is press program & type in the factory code 2 times & that will erase the number you created.
Then to add a new combination all you have to do is: press program followed by 5 new numbers. Then to see if they new number works, just type in the new combination & the green light should come on & you have 4 seconds to turn the handle
Posted on Nov 25, 2008
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Posted on Jan 22, 2009
  • 76 Answers
SOURCE: Need factory code for Sentry Safe Model 1610 -
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Posted on Jul 06, 2010
loxmith
  • 21 Answers
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Posted on Jul 24, 2010
My pilot super safe model number 1610 is open and want to change the code lost manual and can't do it.
Take it to a lock smith, they can fix your problem at a minimal charge.
May 01, 2015 | Home Security
How to open a Sentry 1610 fireproof safe if combonation has been lost?
I would consider drilling out the lock (have locksmith do this)
Sep 06, 2014 | Sentry Fireproof Safe
I have changed the battery in my sentry 1610, no I can't open it with my pin-Nr..
if you have changed the batteries, the code may have reset itself to the default code.
you should be able to find this in the instruction manual or on the manufacturers website.
i am sorry i cannot give you the codes myself, but i do not feel it is appropriate to put default codes for a safe on an open website
Feb 28, 2011 | Sentry Safe Fire-Safe Home/Office Safe
Need factory code for Sentry Safe Model 1610 - know its 5 digits but cant remember - never changed it from factory code but cant find the darn owners manual!
Jun 13, 2010 | Sentry Fireproof Safe
Lost codes
would you know the factory recovery code for sentry 1610 as
i lost it or it is locked in my safe. My battery has been dead
for some time and I think it lost it's memory.
Jul 17, 2009 | Sentry Fireproof Safe
Sentry 1610 safe - battery is dying?
I have 2 Sentry 1610 Safes. A fresh alkaline battery MAY open the safe once (maybe twice), and then the same problem. I have a variable DC power supply that I hook up to the battery terminals, set to 9 volts and increase the current until the keypad responds & the deadbolt releases. Sentry has no solution for this problem, as this model is too old & they have no parts or troubleshooting. If you know someone with a small DC Power Supply, you can get your safe open / closed.
Mar 29, 2009 | Sentry Fireproof Safe
Oct 09, 2008 | Sentry Fireproof Safe
Jul 02, 2008 | Sentry Fireproof Safe
Changing the combination
Apr 24, 2008 | Sentry Fireproof Safe
Mar 29, 2008 | Sentry Fireproof Safe
Home Security Logo
167 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
