Question about Troy-Bilt Troybilt Mtd Roto Tiller Forward Idler Pulley See Models Below
FROZEN TINE PIN REMOVAL - Troy-Bilt Troybilt Mtd Roto Tiller Forward Idler Pulley See Models Below
Troy bilt rear tine tiller will not free wheel. works forward and reverse no problem. Model 12209
are the wheels held on with hitch pins? if yes you have to remove those to roll the beast. remove pin slide wheel to the inside replace pin. i know it sounds silly which is what i thought too. it is what it is. good luck
Jul 04, 2017 | Troy Garden
Tiller transmission frozen
I would take it apart and inspect the inner parts for damage
Sep 16, 2012 | Sears Craftsman 208cc* Counter Rotating...
I have a rear tine craftsman tiller and it keeps breaking the shear pins on the right outer tine. I have replace the pins several times. Same results. What could be causing the problem?
The hole is worn out so the pin has room to move around inside the hole which causes excess wear on the pin...this causes the pin to break after a period of use...
The best fix would be to have the hole welded up and then redrilled to the proper size again..
heatman101
Jun 25, 2011 | Garden
I have a Craftsman 17" rear tine tiller with
check to see if there is a snap ring on the shaft or a roll pin.
Feb 23, 2011 | Craftsman Garden
How do I get the wheel off of my rear tine tiller? They appear to be pressed on and use a bolt or pin to retain them, but I have soaked them with penetrating fluid and used a puller but have not had any...
Did you ever find a solution to removing your tiller wheel ? I have the same problem, tried pullers, heat, hammer, Wd40, everything. I would appreciate your input. Mike. mglobna@yahoo.com
Apr 09, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Rear tine will not turn mod 21b-403-13144-0366-6 huskee
Could be the belt if it has one. If not then your problem could be as simple as a pin broken in the tine shaft. There is also a pin in a gear in the gear box also, This will require shop work.
good luck.
Oct 03, 2009 | Garden
Troybuilt rototiller
Most of them have a pin to lock the wheel to the axle... Check the center hub of the wheel and see if you can find some kind of hole that a pin would go in to lock axle to the wheel...
May 20, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
7 hp pony b & s ...bolts backed out on brg. cap at tine drive gear. Replaced gear and spacers---no drive on wheels or tines. Is there a shear pin or have the brass gear(s) bit the dust? I owned this...
I did not not resolve my problem, instead I went to bed! I will tear the whole thing down and provide results when I get them. Again thanks for the support. JM
Apr 18, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Troybilt Mtd Roto Tiller Forward Idler Pulley See Models Below Logo
263 people viewed this question
Top Troy-Bilt Heavy Machinery Experts
Mike
itsman
ray gallant
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
