Question about Sewing Machines
THE TOP THREAD WILL NOT PICK UP THE BOBBIN THREAD.
  • Anonymous May 01, 2015
    This is a Kenmore center needle, low bar machine
    Novelist:
    Habit-Forming:
  • 97 Answers
Check to make sure the bobbin is free and turns without catching or in a knot. check the tension on your spooler....correct needle installed correctly......correct thread types in both top and bottom sources.....sewing machine is rotating in the correct direction......all parts and gears are working correctly and installed correctly under the plate....
Sorry, that's all I've got for sewing machine repair work on your type of problem.
Good luck and maybe research your problem on-line on your machines manufacturers web site or in forums.
Posted on May 01, 2015
  • Sewing Machines Expert
  • 460 Answers
Have a look on u-tube for timing repairs as this may be a problem too.
Posted on May 02, 2015
All it does is pick up bobbin thread top thread is the problem
The top thread is what pulls up the bobbin thread. What does the stitch look like?
Jan 29, 2014 | Singer CE-100 Futura Computerized Sewing...
Top thread will not pick up bobbin thread on my model 7422
try a new needle--make sure it's the right needle for the fabric
being sewed.
try rethreading the machine top and bobbin --make sure to use
every thread guide
try a different bobbin
it's also possible that the machine could have a timing problem
and needs to be checked
here's a free manual if you need one just click on the link
http://www.singerco.com/uploads/download/f3eff19dd0b1966512ad6a6bd24e3d8a74926fca.pdf
Dec 06, 2012 | Singer 7422
The top thread won't catch the bobbin thread to pull it through. It almost seems like it doesn't go around to pick it up. Or is the bobbin thread supposed to pop up more for pick up? This is my Mom's...
check the needle to see if it's damaged
have a thread tail for the top thread & bobbin thread of 3-4 inches
try this & see if it helps you
make sure there's a 3-4 inch bobbin thread then, hold the top thread tail (3-4 inches) with your fingers away from the needle & then use the handwheel on the right side of the machine & lower the needle down into the bobbin area & see if it pick up the bobbin thread that way
make sure there's no lint or loose threads in bobbin area
Sep 24, 2010 | Sewing Machines
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
Top thread doesn't pick up the bobbin thread (Toyota sewing m.)
Hi! This may sound silly, but if you changed your needle and put it in backwards (which is easy to do), the top thread won't pick up the bottom thread. Take your needle out and check the flat side of the needle shank--which way is it facing? With a lot of the newer machines, the flat side goes to the back, but check your manual to make sure.
Let me know if this helps, ok?
Happy Sewing!
Robbie
Feb 12, 2010 | Sewing Machines
How do you get the needle to go down to pick up the bobbin?
Thread top needle, pull and hold thread in back, make sure your bobbin is threaded and in correctly, turn the wheel toward you it will pick up the bobbin thread and bring it up top. Then seperate your threads up on top. Is that what you were asking?
Sep 22, 2009 | Sewing Machines
Needle will not pick up thread from bobbin
If you have correctly inserted the bobbin, try mmoving the top thread by hand gently up and down into the bobbin area. I let my top needle pick up the bobbin thread this way before using the pedal. I pull a long strand of bobbin thread out before pushing the pedal too.
Sep 21, 2009 | Singer Sewing Machines
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Top thread will not pick up the bobbin thread
Timing is off, is is possible that you broke a needle or sewed over a pin. timing needs to be re set by a professional.
Aug 22, 2009 | Necchi Sewing Machines
Singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Dec 15, 2007 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
