Question about Sunpentown SPT Portable Air Conditioner WA-1340DH
I have a supentime WA1340DH portable AC dual hose. yesterday it didn't blow cool air, and today the fan doesn't work but it turns on.
Yesterday it didn't blow cool air, and today the fan doesn't work but it turns on. i cleaned the filter and no water in unit.
3 Suggested Answers
  • 8 Answers
SOURCE: fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
Posted on Mar 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: Why is my sunpentown WA-1210H portable AC not
Might be a dirty filter, a burnt compressor wire or a bad capacitor. Or it could be a bad thermostat.
Posted on May 10, 2009
Cooling fan temp light stays on when air condition is on. fans are not kicking on. Is it the fan module ?
I didn't know it had a light on the dash that said "cooling fan temp".
My 93 doesn't.
The cooling fans are controlled by the computer and turned on when the ac is running or when the engine reaches 220 degrees.
A mechanic would check the fuse and relay for power and the fan motor for power and ground.
Aug 26, 2012 | Cadillac DeVille Cars & Trucks
Our Danby model dpac 11006 was working fine yesterday but came to put it on today just to find out the ac doesn't work the fan still blows just no cool air . we do hear something in and out like a...
The intermittent sound you're hearing is probably the compressor trying to start. This could be caused by a bad circuit or the compressor motor is seized If the latter is the case, it's time to start shopping for a new AC. As the cost to repair would be almost as much as a new unit depending on the age of your unit. However, compressors usually have a 5 year limited warranty. So check you Owners Manual for details. It may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Danby Portable Air Conditioner
The ac blows but it dosent blow kool fan works and its full of freon what should i do and if it blows kool it only blows kool at night
You have the system leak tested
Then have it evacuated & leaks repaired
& recharged
It only cools at night because it is low on refrigerant
& during the day it is so hot in the condensor
that it boils off refrigerant before the expansion valve
& doesn't cool the evaporator
No -- you can not add & polute the atmoshpere
I would think there may be air in there also
Can not work on it yourself
Jun 30, 2011 | 1995 Mercury Grand Marquis
Fan blows room temp air, I can hear the AC kick in but it only runs for about 30sec to 1min before cutting out and making a sputtering sound that shakes the whole unit. Then it just goes back to blowing...
check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
Aug 30, 2009 | EdgeStar AP420HS Portable Air Conditioner
My sc1 over heats when at idle and only if ac or heat is turned off as soon as i turn onn ac heat drops imediately
you may want to check on the radiator fan. The AC has its own fan and once AC is on, the fan would help bring down the temperature. It is either the fan is not blowing or has become weak. You can check on the fan by pulling out the temp sensor on the lower radiator hose. The fan should blow at full speed when doing this.
Check on the water reserve the water inside it goes down, if not there may be a leak somewhere. Water vapor may be escaping and lessening the effectiveness of the cooling system. This may be a reason why the engine cools down after the AC fan is on.
Jun 16, 2009 | 1995 Saturn Sc
Exhaust fan running slow
sounds like the compressor is turning off cause of high pressure. check the coil that the exhaust hose connects to, if dirty clean it. if the fan is not blowing enough air threw the coil the unit will build up high side pressure and cut out, but will turn back on when pressure drops. if that dont help, maybe the fan motor is bad or needs taken apart and oiled.
May 31, 2009 | Maytag Portable Air Conditioner M6P09S2A
Room temperature reads 95-99 degrees F, not cooling the room
one hose is the heated condensing air and one hose is the intake air. if this unit is not working correctly and u just purchased it take it back. if the landlord will replace it tell them. do not call a service tech to check this unit out if u know 4 sure the temp is set right and it continues to blow hot and the exhaust hose blows outside and the unit is set to cool you are money ahead to replace it. hopefully a landlord or recent purchase can bail you, you can find these units at home depot lowes and get them 4 about 400 dollars. hopefully it's covered somehow by warranty or landlord but the cost for checkout and service will exceed the cost for replacement. have you tried to unplug the unit leave it unplugged and try again. have u cleaned the filter. have you noticed ice anywhere. maybe a light that tells you the drain is plugged i don't wan't to get you're hopes down when you are burning up but check these things and let me know if u see any abnormalities. do you leave the unit running in hopes that you will come home and it works? check for ice is there air blowing constantly? if u dont get air flow you could have a fan thats out or its iced up. let me know.
May 25, 2009 | Haier HPAC99ER Air Conditioner
Will not cool
I bought the same unit yesterday and took it back today. Not sure what's wrong, I guess they are junky a/c's.
Jun 10, 2008 | Danby Portable Air Conditioner
Sunpentown SPT Portable Air Conditioner WA-1340DH Logo
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
