Question about Carrier Heating & Cooling
Question about Air Conditioners Open Question Temp on remote screen switched from C to F - How get back to C ?
    Sergeant:
  • 186 Answers
Call your local Carrier dealer and ask them.
Posted on May 01, 2015
  • Raul Leske
    Raul Leske May 01, 2015
    Local Carrier dealer was 1st action. You are not trying very hard, are you ?
  • Jim Evans May 01, 2015
    Just trying to be helpful and you should of said that in the first place. Also i don't need your attitude. It's also not my air conditioner in the first place, so now, i don't care.
Different brand and model has different remote controls, you need to be specific about what model you're asking.
May 01, 2015 | Heating & Cooling
Even though the remote has lights on the split system air con. does not respond to the remote. We can operate the system manually but the remote is 'lights are on no ones home'!!
the remote may havce bad battery connections? bad battries? be locked off? remove and replace battries. locate program switch on wall stat. temp set to energy saving mode. set out of temp set up-back mode to run in on-off-on mode non occupied
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Heating & Cooling
I have a intertherm furnace modelm1mb o7oabw, the diagnostic light flashes once for limit switch open,but i've replaced the limit switches,any ideas?
Hello, a limit switch will open for the following reasons, dirty plugged filter, blower motor not operating on correct speed or weak, too high gas pressure to burners. If you have a thermometer you can check the temp rise of the furnace by measuring the return air temp and the supply air temp and then the differance between the two numbers will give you your temp rise, compare it to the temp rise that is stated on the furncae data plate. if you are not in the range of what the data plate states then start with the filter and check the blower motor to make sure it is operating correctly.
Feb 08, 2011 | Intertherm Heating & Cooling
I have an electrolux split system airconditioner model no.EJE24HRA it has not been used for months but the display panel is suddenly flashing Auto and if I do turn it on it suddenly switches itself off...
there is a auto switch button inside the indoor unit just above or on the side of digital display but you must open front panel to get access to it when you do, press that button which says auto once to cancell it from coming on than set your mode on the remote to heating then press start or on button on remote. be sure to set temp to atleast 30 degree before starting it
Sep 27, 2009 | Electrolux E23CS75SS Air Conditioner
Is there anyway to operate the unit without the remote beyond the on off switch
yes we lost our remote but found that our tv remote will control the ac we can adjust settings and temp we just had to push buttons on the tv remote until we figured out which ones did what
Aug 17, 2009 | Haier HWR05XC7 Wall/Window Air Conditioner
Fujitsu remote control unit /MODEL AR-RY16
my remote went blank suddenly. I replaced the batteries and nothing happened. what can I try?
Jun 07, 2008 | Fujitsu 24C1 Air Conditioner
SANYO REMOTE COTROL
1.check remote its working properly or not.
2.check temperature control switch.
3.put the temperature put below 16 n on the unit
4.if not working change the remote
Mar 27, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
